Audio Research SP9 Circuit Diagram HELP! - Page 3 - diyAudio
Old 2nd March 2008, 04:07 PM   #21
caliban is offline caliban  United States
Yes, I did. I will try sending one page at a time to see if that works, stand by.
Old 2nd March 2008, 04:31 PM   #22
http://s53.photobucket.com/albums/g73/porporpor/
V -- I uploaded the schematics to PhotoBucket, they are slightly smaller due to the website constraints, but I think they will be large enough. Click on the image for a full size view.
This has to work. I have no idea why the email has not.
Old 2nd March 2008, 05:31 PM   #23
Valde is offline Valde  Denmark
Thanks again for your effort, Caliban! I got it know
Valde
Old 4th March 2008, 09:03 AM   #24
Luke is offline Luke  New Zealand
Send a message via AIM to Luke
Hi Brett,
Ive thought about building allen wrights pre, need to buy the book first dont you? Ive read a few good things about his rtp3c.
It seems wrong to use transformers in a preamp, surely you can do as well if not better without this added expense?
Old 4th March 2008, 11:06 AM   #25
Brett's Avatar
Hi Brett,
Nope, I've bought it but built from the schematic.
Wrong, why? They work well, sound better than caps and give galanic isolation. Sure they can be a bit exxy, but so can caps and the RTP3 linestage is a difficult and potentially expensive build with 5 envelopes/channel. I preferred a similar line stage to what I suggested above to the RTP. Allen will no doubt disagree, but I've built both.
Old 12th July 2012, 02:26 PM   #26
Trying not to drag up such an old thread but I was looking in the schematics, specifically in the power-supply section in regards to voltage change.
Is there dual taps for both 50 and 60Hz voltage frequencies? What about going from a 110volt country to a 220volt. I have my SP-9 maybe being sent here to me here in Germany from Canada and wonder if this will work, or a step down transformer may.
thx
Shamus
Audio Research LS15 circuit and description analog_sa Tubes / Valves 1 13th May 2009 02:28 AM
Cambridge Audio IsoMagic & DisMagic problem - circuit diagram? jdunham Digital Source 51 24th December 2007 03:00 AM
Cambridge Audio CD5 output stage (circuit diagram) 316a Digital Source 0 15th May 2007 05:57 PM
Copyright 1999-2017 diyAudio
