diyAudio Sponsor
Old 1st September 2006, 10:32 AM   #1
Alastair E's Avatar
Default Measuring approx RMS power O/P
Sorry, My brain has definately gone today.....
Cant remember the 'proper way to calculate the O/P power in watts RMS of my amp...
Im getting 60V Peak To Peak, 30V Peak? into 8 Ohm Non inductive resistor @ 1KHz just before apparent clipping, measured on O'Scope......
Could one of you great brains tell me the correct way to calculate this....?
Das Beste Oder Nichts
Old 1st September 2006, 10:47 AM   #2
jane is offline jane  Norway
jane's Avatar
Po = (Vpeak)^2 / (2 x Rload)
or
Po = (Vrms)^2 / Rload
Vrms = Vpeak / sqrt(2)
Life is hard - Then you die.
Old 1st September 2006, 02:38 PM   #3
Alastair E's Avatar
or
Err, Not sure what '^' is supposed to mean....Sorry.....
Old 1st September 2006, 02:43 PM   #4
dnsey is offline dnsey  United Kingdom
^ Means "raised to the power of", so x^2 is "x squared".
BTW, there's no such thing as RMS power (just kidding, we all use the term!)
Old 1st September 2006, 04:37 PM   #5
Alastair E's Avatar
Right....
So V Peak, (half the P-P value) 30 x 30 is 900.
And 8 Ohm x 2 is 16....
900 Divided by 16 is 56.......
56W RMS from a single pair of 6C33C-B in Circlotron OTL.....Sure, That can't be right......? Thats around 7.5 AMPS per 6C33c Peak Current!-
(8 ohm, 60V peak-peak, Each one must be conducting the 7.5A, OR am I missing summit........)
(The pair is being run at 75mA idle current, and 190V per circlotron supply, with diff-amp feedback drive. The grids go positive around 30V on peaks, Checked all supplies and settings again today....)
-This sort of power from just 2 bottles in the O/P stage just aint possible surely...??!
It does sound VERY loud when you turn the wick up though, but still great sound......)
Checked the readings and scope-settings again this afternoon......
Something silly going on here.....! Told you...My brain aint that good today, so please go easy on me.....
Old 2nd September 2006, 07:58 AM   #6
60V Pk-Pk is 30V Pk, 30V Pk will be 30/1.4142 = 21.21V RMS, output power is VRMS^2/Rload so in this case 21.21^2/8 = 56.25W
The power calculation is OK but your calculation of Peak current is not.
Pk current for one tube is Vpk/Rload so in this case it is 30/8 = 3.75A, it is still very high but not too high, I have seen peak currents of up to 3A for a single 6C33C but I have never used positive grid voltage.
It is also interesting to calculate the dissipated power of your tubes as you are quite much over the max rating of 60W.
We calculated the peak current to 3.75A, it can be showned that the average current drawn from the power supply will be Ipk/Pi so in trhis case Iavg is 3.75/3.14 = 1.2A, the power supply voltage is 2*190V so the power drawn from the power supply is 380 * 1.2 = 456W, from this we remove the output power of 56W and end up with a dissipated power of 2 tubes of 400W or 200W per tube.
I expect that the anodes will glow red if you run full power for anything shorter than a minute or so. With music it is still probably alright as average output power is 10 - 20dB lower than peak, say 15dB as average, then you will have an average output power of ~1.8W and the average current will also be lower at around 0.2A with a power dissipation of 38W per tube so well inside the ratings.
Regards Hans
Old 2nd September 2006, 11:18 AM   #7
Alastair E's Avatar
Thanks Hans, I probably am running them pretty hard, but then again on music at a moderate volume, the dissipation as you say is very much lower. The full-power tests were only done for a matter of seconds, as any form of continuous high diss test like this would probably kill the tubes after a much more....
When I was thinking of the peak current, I was for some silly rerason thinking that the full current must be passing each tube, but logical thinking being a circlotron with one tube per 'circlotron rail' then the peak current will be halved, each supplying just half the peak current
Pretty pleased with my efforts, Time to breadboard up the other channel for some serious listening, testing, tweaking etc before I commit to a 'Proper' build in a nice box......
As to reliability, I guess providing I treat it with respect and dont show it TOO much heavy-rock, then things 'should...' be fairly reliable. Generally day-to-day running when not using my prototypes for serious listening I tend to run the TV/DVD sound through them. Ive used this single-channel circlotron for around 8 months with few if any real issues, just the odd change/mod here and there mainly on the pre-amp/phase-splitter side.
Great advice on your site about 'Pre-Conditioning' the 6C33. I have done this on all but a couple of tubes. I just let them run for around 3 days just heaters then use them. Only 'failure' I had was with a tube that hadnt been 'pre-conditioned'., when I did some power-tests some months ago....Strange thing about that tube, Left it running in the amp and it slowly came back to life.....Probably not for long though!--Maybe Ill try heaters only for a week on it to see what happens
Old 2nd September 2006, 11:57 AM   #8
Hi Alastair,
Glad to hear that it works well, and it shouldn't be a any problem when playing music.
I don't think it matter at all what kind of music you play as the peak to average ratio is at least 10 to 1. What is killing OTL amplifiers is IMHO either too high idle dissipation or current runaway due to badly matched parallell connected tubes.
My own OTL is not running positive grids but I get about 25W output power with +- 150V. The dissipation at full output power is about 110W per tube but I have done a test where I let the amplifier run at full output power for 24 hours and there where no ill effects, everything got very hot of course but nothing broke and the anodes doesn't even get red at this power level so I believe that 60W is a very conservative spec, BTW I still use the same 4 output tubes as I used from the beginning, that is now more than 6 years of use without problems. The idle dissipation is ~30W per tube and at that level they have very long life time.
Regards Hans
Old 2nd September 2006, 03:09 PM   #9
Alastair E's Avatar
Originally posted by tubetvr
Hi Alastair,
Regards Hans
I'm of the same opinion concerning the reliability of the '33 in 'home-build/audiophile amps....
The average 'home designed'/built OTL seems to run Very high idle dissipations, and Very HOT in order to reduce O/P impedances...Seems a lot of guys consider this to be the Main factor above all in their otherwise good designs The trend for very low or No neg feedback demands that they need high currents to lower O/P impedances....
(Ive seen on the 'web, a guy running at 400 mA and 120V on his 6C33 OTL.......The way I look at it, he only has 200mA 'headroom' before the max current rating is exceeded....A little ageing of the tube or thermal run-away even a slightly higher than normal line-volts and There-You Go,-- One or several Cooked Tubes--He didnt comment on reliability!....)
My personal opinion is that neg feedback is a good thing IF used where really needed and done 'sparingly'
The 'diff-amps' (6SL7GT) at the centre of my OTL allow me 100% neg feedback Just Round the O/P stages-Only where needed, making the O/P tubes just a buffer-stage, allowing me to use as low as only 50mA idle-current, although its usually set at around 75mA. Thats only 14 watts idle-dissipation-In comparison to running 200mA @ 150V which were the settings when I first constructed an OTL, the tubes practically stay 'cold'! I havent tested the O/P Impedance, something I forgot to do yesterday--Can't be too high though, Did a quick frequency sweep, get flat response from 12Hz to 300 odd KHz-Happy with that!....
The 6C33C-B has got to be one of my favorite valves too Built like a brick-outhouse, pretty good sounding very reliable if used with care and best of all, DIRT CHEAP !
The current pair in my bread-board, have been used and REALLY abused many times both in SET designs (Running VERY hot in those...) and other OTL experiments Had the pair glowing orange in the anodes a few times during experimentation when some MOSFETS failed in the drive CCT of a previous design I was convinced they would be toast, but no, they battle on just great. with little or no apparent harm--I would Love to see a 300B that would do that!
Old 11th September 2006, 09:21 AM   #10
KimBOlesen's Avatar
Send a message via MSN to KimBOlesen
Hi
Can you post a schematic of your OTL, or a link? Think OTL will be my next project.
Best regards
Kim Olesen
Measuring Output Power Rodango Tubes / Valves 5 30th September 2008 12:32 AM
measuring the noise of a power supply pjpoes Power Supplies 6 31st March 2008 06:19 PM
Thumb Rule for determining Approx output power of class AB amp rajeev luthra Solid State 12 3rd August 2004 07:34 PM
measuring output power MikeZ Pass Labs 14 1st December 2003 06:16 PM
Measuring amp output power fragman56 Tubes / Valves 15 26th May 2003 08:26 AM
Page generated in 0.14103 seconds (83.94% PHP - 16.06% MySQL) with 10 queries
