| diyAudio Sponsor | ||
Hello, I am so hungry to build another power amp. I am trying to decied between an El34 PP triode design, or just a PSET design.
I am having trouble finding PSET designs for just 2 El34s Per Channel. Will El34s running in PP in triode mode even go beyond Class A? Would someone please direct me toward a good PSE design that uses 2 tubes per channel? I am dying to try this out. Or as I am still a newbie, should I build a PP amp first before I try PSE? I am lost! please help me! -Moose |
#2 |
Triode, UL, or pentode, how you bias the tube determines the class of operation. Only Class "A" is suitable for HIFI when SE topology is employed. You have options when PP "finals" are used. IMO, "shallow" Class "A" operation has a lot going for it. You squeeze out a little more when peak power O/P is needed, while avoiding cross over problems most of the time.
Eli D. |
#3 |
2 tube PSE, I will tell you what I do. If the power supply in your existing amp is capable of supplying twice the current, you can do this. Wire a second (same brand) EL34 directly in parallel with the existing tube. The best way to do this is to use seperate stopper resistors for each tube. The cathode resistor now needs to be half its original value. The output transformer must now be half its impedance also. This will double the output power, so to take advantage of this power, you need a larger transformrer
Running two tubes in P-P allows the tubes to operate in class A, B, AB1, or AB2. A SE amp must always run in class A
Too much power is almost enough! Turn it up till it explodes - then back up just a little. |
#4 |
diyAudio Moderator Emeritus
Exactly as Eli says. From class A in triode PP, you only get 12w output. In class AB1, you can get 16w. I doubt if anyone would be able to tell the difference, in terms of distortion.
#5 | |
Hi Alex,
Also, this extreme 4*PSET one comes to mind. Tom
If in doubt, just measure. |
#6 | |
What speaker did u use ? if not more than 90db ... please dont built it !! complete waste of $$$$ !! unless u built for ... hobby |
#7 |
my speakers are 90 db, they get loud enough with one Triode-connected EL34 per channel, so I am just looking to add a little more *umph* in a new amplifier
#8 |
I seriously doubt that, beyond a certain minimum threshold, more watts equal more oomph. My 94db/w backloaded horns sound more powerful when driven by a 1.5watt el84 set when compared to an el34pp, 30watts/channel. You could also try to connect the el34's screen with the Bill Perkins gizmo, this will give a lot more attack to the overall sound + tighter basses. A somewhat weak, smudged sound is inherent not in low-powered amps but a result of the conventional resistor triode-strapping method.
Simon |
#9 |
More watts means more oomph right out to the limits of the speaker. Its just that the numbers get big in a hurry due to the exponential relationships.
It takes about 10x the power for something to be percieved as twice as loud, depending.
Be sure your foil hat has a good low impedance ground. |
#10 | |
There's that famous phrase: If the first watt doesn't sound good, etc... Quantity won't solve a quality problem Simon |
| My El34 SET | alexmoose | Tubes / Valves | 10 | 9th May 2006 09:10 PM |
| EL34 CCS help | navin | Tubes / Valves | 2 | 25th March 2006 03:59 AM |
| 4 x PSE EL34 | Hojvaelde | Tubes / Valves | 1 | 24th March 2006 02:26 PM |
| 6L6 vs EL34 | resident | Tubes / Valves | 20 | 13th October 2004 07:37 AM |
| Page generated in 0.10444 seconds (85.18% PHP - 14.82% MySQL) with 11 queries |
