diyAudio Sponsor
Old 4th September 2006, 06:35 PM   #41
This?
Old 4th September 2006, 08:46 PM   #42
Brian Beck's Avatar
Yep, try that.
Brian
Old 4th September 2006, 08:57 PM   #43
Well, I have to build the amp first, haha
Old 6th September 2006, 01:53 AM   #44
tubelab.com's Avatar
Look at the LM334Z. Morgan Jones used them in a few of his amps. If you have the third edition, check pages 476, 477, 478, and 484. I have used them also with a 6J6 and a 12AT7. In most cases the negative voltage can be eliminated, just connect it to ground. In my 12AT7 bases phase splitter, I think that it may sound better with a negative 5 volts applied. These are only good for 10 mA though.
As mentioned before the LM317 sounds like **** when signal is applied to it. I would try the LM334Z. If you are going to use a negative voltage, then just use the IXYS10M45 chip, instead of your cascode circuit. It is good to several hundred KHz, and it sounds good too.
Too much power is almost enough! Turn it up till it explodes - then back up just a little.
Old 6th September 2006, 02:26 AM   #45
If I am going to place an order to Digikey, I might as well use the 10m45 to CCS load the 12at7? should I do this for both the driver, and the phase inverter? or just the driver?
Old 6th September 2006, 08:21 AM   #46
mus is offline mus  Canada
How about the DIY-CCS? I think they are good!
Old 6th September 2006, 12:50 PM   #47
The schematic that you show in post #33 uses a 12AT7 as the Long Tailed Pair, which is both the phase splitter and the driver. In this circuit you want just one CCS in the cathode circuit as shown. The plates should be loaded with resistors as shown. More than one CCS per circuit generally causes them to fight each other leading to instability and general bad behavior. Copy the circuit as shown, just replace the LM317 circuit with the CCS circuit of your choice. As pointed out here there are plenty of them to choose from.
Old 6th September 2006, 05:44 PM   #48
okay, I have seen to LEDs fight before, I guess it makes sense for all CCS's. I have no clue when construction on this amp will begin, I have the money to build, but now being a full-time student, and with little labspace, I will just take it slow and Steady. I've heard that the best
DIY is done that way
My El34 SET alexmoose Tubes / Valves 10 9th May 2006 08:10 PM
EL34 CCS help navin Tubes / Valves 2 25th March 2006 02:59 AM
4 x PSE EL34 Hojvaelde Tubes / Valves 1 24th March 2006 01:26 PM
6L6 vs EL34 resident Tubes / Valves 20 13th October 2004 06:37 AM
Page generated in 0.07780 seconds (84.52% PHP - 15.48% MySQL) with 11 queries
