diyAudio Sponsor
Old 30th August 2006, 02:57 PM   #11
Klimon is offline Klimon  Belgium
Thanks for the abundance of replies !!
Since the consensus seems to be that the difference will be minimal or non-existant I'll stick with the trusty HG-10s
Simon
Old 30th August 2006, 06:09 PM   #12
Sherman is offline Sherman  United States
Originally posted by Geek
...Unbypassed, the non inductive types (all but the regular WW and metal film) had a slight edge above 30KHz, especially on the squarewave response into complex loads.
Man, I think you just posted the answer to something that has been puzzling me for a while in a test amp I have!
Now to the bench to swap a couple resistors and put it on the scope!
Thanks,
Edit: I can't hear the difference but I can see it.
--Sherman
Old 30th August 2006, 10:19 PM   #13
Geek's Avatar
Yup, pretty much what I found too. They all sounded the same to me, but the 'scope saw a difference.
I ended up using metal composition in my designs simply because they were the smallest for the 3 watt rating that sufficed.
Vitreous Enamel vs Wirewound Resistor Valverine Tubes / Valves 31 2nd September 2010 08:55 AM
TVA-1 cathode resistor value audiohead Tubes / Valves 3 9th December 2007 07:15 PM
Wirewound Pot Law Fake with Wirewound Resistor wrenchone Solid State 6 13th September 2007 06:45 AM
Is a Vitreous Enamel wirewound resistor a good replacement? erkess66 Parts 1 8th December 2006 09:26 AM
large value wirewound resistor... contaxchen Parts 3 15th April 2004 05:22 PM
Page generated in 0.07601 seconds (73.84% PHP - 26.16% MySQL) with 10 queries
