diyAudio Sponsor
Old 18th January 2005, 12:03 AM   #101
yahzdi is offline yahzdi  United States
Default Quicksilver KT 88 schematic
Here is a work in proress schematic of my stock KT88 without power supply section. Some values missing and no guarantees, but it may be useful.
Old 18th January 2005, 12:17 AM   #102
I don't see it
Old 18th January 2005, 11:18 AM   #103
But now I do
Old 8th February 2005, 08:03 PM   #104
Default Quicksilver KT88 Schematic
There were definitely some circuit drawing errors in the previous PDF file. I have corrected them and here is the result. The pink rectangular things referred to are probably the mica caps reffered to earlier. The exact wiring around the bias jack is probably not quite right, but it is close enough to get the idea. The source file is in Microsoft Visio. I will send it to you if you want it. Contact me at yahzdi@pointroberts.net.
File Type: pdf quicksilver kt88 schematic corrected.pdf (24.2 KB, 146 views)
Old 8th February 2005, 08:50 PM   #105
Once I put it out there for comment it occurred to me it would be useful to label everything for reference. I also made the mystery component a cap instead of a diode.
File Type: pdf quicksilver kt88 schematic corrected and annotated.pdf (24.5 KB, 219 views)
Old 9th February 2005, 06:38 AM   #106
Default Quicksilver KT88 schematic
Now I know this is a really old thread, but I would appreciate suggestions for tweaking these amps. Currently I am planning on replacing the .27uf coupling caps with .22 and .047 multicap RTXs in parallel. Also replacing the input bridge resistors with Vishay S102s (at $24 each), and the R15 and R16 signal path resistors with Kiwame 2 watt carbon film resistors. I am putting Vampire CMF2/OFC RCA jacks in and wiring the new connectors with silver wire. Most of these ideas came from this thread. Comments please. Thanks.
PP KT88 Mono blocks? TubeMack Tubes / Valves 38 11th June 2009 05:41 PM
Quicksilver 300b monoblock (KT88 conversion) eleakist Tubes / Valves 4 18th June 2007 11:50 AM
Quicksilver mini mono block amps? Original Burnedfingers Tubes / Valves 2 15th March 2006 11:47 AM
Quicksilver Mono 60 upgrades labjr Tubes / Valves 4 16th February 2005 02:21 PM
For Sale: Quicksilver Horn Mono's BHD Swap Meet 1 10th September 2004 02:18 AM
Page generated in 0.08679 seconds (80.30% PHP - 19.70% MySQL) with 11 queries
