| diyAudio Sponsor | ||
Hi all,
I want to make a tube hybrid, and i was looking for a bit of advice. Am i correct when i say a tube hybrid is effectively a tube pre-amp and a MOSFET power amp? If so, has someone made one that is fairly simple, preferably requiring only one or two tubes? Thanks in advance, --neg |
#2 |
"There's something organic about a happy cloud of electrons" - Neutron Bob |
#3 |
Here is one that is turning in to a hybrid.
Regards Åke |
#4 |
Check the nice simple htbrids here http://www.wdehaan.demon.nl/hybrid/
I built the "Design Using 5687 Tube". I love it. If high voltages worry you try the battery tube version.
For me the past is not over yet. |
#5 |
diyAudio Moderator Emeritus
Hybrid is a pretty broad term, when applied to trasistors and tubes. It just means a mixture of the two and can be a tube preamp with SS power amp, as you describe, or it can be the other way around. Many people value the sound of tubes in a power amp because they tend to have a more gentle overload character that an SS amp. Preamp sstages are often seen as OK with either tubes or SS, since overload is usually virtually impossible. Let's be honest, these days a lot of music sources (CD, DVD, cassette tapes, radios, etc.) use SS.
#6 |
Valve-buffered gainclone. About as simple as you can get for a hybrid. Build a "gainclone" with LM3886 ot LM3875 chips. Then just add a cathode follower front-end with a 6922 tube.
Search the Chipamp forum for 'valve buffered' or 'tube buffered'.
--Sherman |
#7 |
Careful when loading a tubes' plate with a MOSFET gate. The MOSFET's Crss capacitance can be large and is guaranteed to be non-linear. See other discussions about this effect in other threads.
Brian |
#8 | |
--Sherman |
#9 | |
Regards Åke |
#10 |
Depends what you mean by "do the job". I guess you could say that a any SS amp will "do the job".
But the RC time constant of a 6C45 plate looking into the horrendously non-linear capacitance of a MOSFET gate will still produce phase shift in the audio band, and non-linear phase shift at that. Some people won't mind the resultant sound. More etch. More zip. As we discussed in another thread, one solution is to increase the MOSFET's drain voltage way up to 100 or 200 volts, reducing and flattening Crss. The other solution, better in my view, is to use a CF or even a White follower.
Brian |
| Hybrid Amp, Tube+MOS FET SE | ja2dhc | Tubes / Valves | 2 | 5th July 2008 02:12 PM |
| Hybrid amp -> tube for VAS stage | rtarbell | Tubes / Valves | 3 | 26th November 2005 09:13 PM |
| tube/SS hybrid (low power)- need tube help | trespasser_guy | Tubes / Valves | 26 | 6th July 2003 07:15 PM |
| tube/ss hybrid mic preamp help! | mwmitchell | Solid State | 0 | 4th August 2002 01:11 PM |
| Page generated in 0.11234 seconds (83.47% PHP - 16.53% MySQL) with 10 queries |
