| diyAudio Sponsor | ||
Can a make anything usefull from some 5686 Pentode tubes?
#2 |
I have a big box full of these but I have only done some basic testing. This tube is rated for audio amplifier use, but I didn't try to use it as a power amp because I have a lot of other tubes that will make more power. I tried it as a cathode follower driver tube. It worked OK but the 12BY7 worked better. I will try it as a voltage amplifier at a later date.
It could be used for a low power amplifier, maybe 1 watt SE triode, 3 W SE pentode, maybe 10 W PP pentode. I would try 200 to 225 volts of B+ maybe 250 with cathode bias. The data sheet shows a 9K ohm load in SE pentode mode. If you want to experiment with this tube, try an EL84 circuit, with lower B+ voltage. I figured that the other parts for the amp would be worth more than the tubes, so if you were going to buy all of the parts for this amp, then spring for some EL84's. If you have the parts to experiment, then try it. I have a larger box full of 6AQ5's so I am experimenting with them instead. One more thing, these tubes like to oscillate. Use grid and screen stoppers.
Too much power is almost enough! Turn it up till it explodes - then back up just a little. |
| Trimodal amplifier schematic | princesa | Solid State | 1 | 22nd January 2009 10:03 PM |
| Take a look on amplifier schematic please | viktor1986 | Solid State | 51 | 11th February 2006 08:35 AM |
| Schematic: Russound amplifier? | ken.berg | Solid State | 0 | 21st April 2005 01:24 AM |
| Need a amplifier schematic | mbates14 | Solid State | 3 | 13th September 2002 08:12 PM |
| 15W SE amplifier schematic | SteveS | Solid State | 11 | 11th April 2002 10:03 PM |
| Page generated in 0.06979 seconds (68.29% PHP - 31.71% MySQL) with 10 queries |
