diyAudio Sponsor
Old 17th August 2006, 11:32 AM   #1
Default 5693 as a phono preamp?
Just wondering if someone has had experience using a 5693/6SJ7 as a phono preamp. If so do you have any schematics to share?
Old 17th August 2006, 01:14 PM   #2
SY's Avatar
Triode connected?
“Listening to records is like ****ing a picture of Brigitte Bardot.” - Sergiu Celibidache
Old 17th August 2006, 11:43 PM   #3
Well, it only has an amplification factor of 19 when it is triode connected. I cannot find the amplification factor in pentode. Maybe its not a good choice after all.
Old 18th August 2006, 01:10 AM   #4
SY's Avatar
Pentodes in general aren't good phono stage tubes because of partition noise, the excess noise inherent in pentodes because of the statistical nature of electron flow when given a choice between screen and plate. In this service, you'd do better with a triode. The 5691 could be a good choice if you can live with the input capacitance (a few hundred pF).
new phono stage or old preamp with phono? flohmann Analog Line Level 2 2nd October 2008 09:51 PM
phono preamp wombil Solid State 5 21st May 2008 11:59 AM
Electret mic preamp - will phono preamp work? darthmullet Analogue Source 6 12th October 2007 07:32 AM
Phono PreAmp JTT Analogue Source 20 15th September 2004 04:24 PM
Phono Preamp. victor Pass Labs 0 24th October 2001 07:11 AM
Page generated in 0.07500 seconds (65.33% PHP - 34.67% MySQL) with 10 queries
