| diyAudio Sponsor | ||
How do you apply a common mode choke in a filament supply? Do you put one in series with each 6.3 volt filament or in parrallel with all of them. Also what size do you use? My guess is that you would put them in series with each filament. But that is just a guess.
G
Gavin |
#2 |
diyAudio Moderator Emeritus
Hi..a common mode filter..as I see it is just a choke in the positive AND the negative voltage rail... With the difference that they are connected to the same core.
I use a mains filter ..commonly used before the transformer in ..say a cd player.. but instead I use it in the filament of my driver tube... So each "inductor" will be in series on each rail..but the two inductors will be "parallel".. Hope this helps.. Regards, Bas |
#4 |
Thanks Bas. Is there a certain value that you prefer to use for filament supplies? Also, would putting a capacitor across the line at each filament in addition to the CMC would help also. Thanks for the info.
G
Gavin |
#5 |
Hi G,
Nope I use any value really. And yes, putting a cap a cap across the filament would indeed help. I also use this.. But better still would be to use 2 caps...one on each leg of the filament...and each one to ground...this would be the "second" part of your filter.. So that you would have a LC filter on each leg.. Cheers, Bas |
#6 |
Thanks for that Bas. I was looking for an image to post with an explanation earlier tonight before I went out, but it looks like you beat me to it.
Cheers |
#8 |
O.. hi Brett..
I thought G posted that.. :-) By the way..do you think it is worthwile doing this..on an IDH tube..I did it on my 6n1p driver..but I am to lazy to undo it to check if it makes a difference.. Cheers, Bas |
#9 | |
I buy mine from an industrial parts supplier, and get the biggest value CM choke I can, usually in the order of a few mH or more depending upon the current rating. Larger 100mH are about $5 and I'm going to add some of these to my MC phono stage when it's apart next. As noted elsewhere, a CM choke won't reduce hum, unless it's a couple of orders of magnitude larger, and probably more expensive too. |
| common-mode chokes | jarthel | Tubes / Valves | 6 | 11th February 2008 04:31 PM |
| Common-mode EI PS Chokes | rdf | Tubes / Valves | 14 | 17th June 2007 09:36 AM |
| Common Mode Chokes for Heater Supplies | ppereira | Tubes / Valves | 7 | 29th January 2006 02:45 PM |
| Source for common mode chokes | abj1 | Tubes / Valves | 7 | 24th June 2005 07:31 AM |
| Common mode chokes | Dr.H | Digital Source | 1 | 24th July 2002 05:47 PM |
| Page generated in 0.10915 seconds (72.78% PHP - 27.22% MySQL) with 11 queries |
