Confused, datasheet of 417A/5842
Old 16th August 2006, 03:48 AM   #1
CLS is offline CLS  Taiwan
Question Confused, datasheet of 417A/5842
Hi there,
I've been playing around the operation points of my Euridice pre these days.
Previoulsy, I ran the tubes on around 135V on anode & 1.2V cathode bias to get 24~25mA.
Recently, I raised the Va to 160V & 2.1~2.2V cathode bias to get 17~18mA.
I found the latter is more open & dynamic. Extremely extended on high & lots of lots of details. In good recordings, cymbals are so sparkling & the decay is so airy. The textures & overtones of acoustic instruments are fabulous. Bad thing is, it reveals more shortcomings on bad recordings & let them sound even worse, especially the mid-high harshness.
Meantime, I rechecked the datasheets, & found something I can not put together.
This is digested from the datasheet of WE417A:
How strange is that!
The note says it's the voltage across grid & "negative" end of cathode resistor. But how is that possible? +7.5V !!
On the datasheet of Raytheon, there's even more, Va=130V, Rcathode=360R, Va=27mA, Vg=+9V !!
Can anyone explain it to me?
Thanks a lot!
The curves:
This is my setting presently, load line is 5K, -2.2V on grid is obtained from red LED on cathode. Actually I got slightly more current than the diagram is shown. I'm not sure how much difference would be among different brands of tubes. I don't have WE yet. Under the same voltages, Amperex flows even more than Raytheon. And the Raytheon actually flow more than WE datasheet....
How do you setup your 417/5842? And how do you like them?
I always read here & there that the WE tube is MUCH superior than others. How true is that?
Call me deaf, I confess, those different brands of tubes in the same type sound very similar to me. I have to listen very hard to tell the subtle differnces. Sometimes, maybe the so-called differences are just my own imaginations, as I'm continuously hinted by myself.
By contrast, different operation points sound much much more significant to me. As in the speaker tunings, I don't play with cables or different brands of caps, I change the parts' values to alter the response... Well, that's me.
Back to the 5842/417A, I'm told the Amperex is superior to Raytheon. My feeling is, well, maybe, but the difference is subtle. Nothing wrong with Raytheon, they sound very good, too.
I'm told the WE is excellent in the mid-high. But how much more? How airy? Into the edge of atmasphere & outer space? I can only imagine until I get them....
Old 16th August 2006, 04:48 AM   #2
arnoldc is offline arnoldc  Philippines
Send a message via Yahoo to arnoldc
a) diyAudio CCS @ 10mA and Orange LED
b) plate choke and Orange LED (~10mA)
Obviously, I like them at that current
c) 5K load, 20mA spud amp configuration.
I like it too.
Superior in what sense?
Agree.
I have all three. The Amperex Gold pins are "darker" compared to the Raytheon, and the Raytheon is "darker" compared to the WE417A.
Old 16th August 2006, 05:00 AM   #3
rpapps is offline rpapps  Antarctica
Default Re: Confused, datasheet of 417A/5842
Thanks a lot!
Hi CLS
I believe they are referring to the voltage developed across the cathode resistor. If you multiply the current and resistance you get approximately the figure quoted.
You can't accurately measure grid to cathode voltage because meter loading will give you a false reading.
Cheers
Rob
Old 16th August 2006, 05:32 AM   #4
Thanks for reply.
arnoldc,
I did notice the Amperex is slightly softer & rounded than Raytheon. As mentioned, the difference is subtle to me.
After raising the voltage & decreasing current, I felt they're already a little too bright to my ears. If WE is even brighter, I think I have to turn it down by the DEQ or make some other system tuning...
rpapps,
That makes sense! Thanks.
Old 16th August 2006, 04:34 PM   #5
AndreasS is offline AndreasS  Germany
The 417A is a high Gm valve, the transconductance for DC S= So / 1+ So * Rk.
Increasing Rk stabilisizes operation point for DC.
Regards Andreas
Old 16th August 2006, 10:53 PM   #6
Robert McLean is offline Robert McLean  Canada
CLS
The data sheet makes perfect sense, you just have to remember the plate curves and your measurements are with respect to cathode, but the data sheet voltages are with respect to circuit common, aka "ground".
23mA through the cathode resistor of 360 ohms is 8.28 volts. The grid is 7.5 volts with respect to the negative end of that resistor (what I would call circuit common), so in other words the grid is -.78 volts with respect to cathode. Plate to cathode voltage is 130 - 8.28 = 121.72 volts. So this is indicating 23 mA at 122 plate volts and -.8 volts bias, in round numbers. This is in line with your actual 25mA at 135V and 1.2 bias, and also matches exactly the plate curves you show.
Robert McLean
Old 16th August 2006, 11:10 PM   #7
Default oops
It looks like I can type faster than I can think. I have obviously forgotten to take the load resistance of 1850 ohms into account. At 23mA this drops 42.55 volts, so plate to cathode voltage will be 79.17 volts. This is indicating 23 mA at 79.2 plate volts and .8 volts bias, while the plate curves show about 8 mA at that bias.
So it seems there is an inconsistancy here after all.
Robert McLean
Old 17th August 2006, 01:15 AM   #8
I suppose the 1850 Ohm is not the "load", but the Ra.
So the previous calculation seemed right to me.
Old 17th August 2006, 11:23 PM   #9
DOH!
of course CLS you are right, it is Ra, I got it right the first time. So I was seeing problems where there were none.
Robert McLean
Old 22nd August 2006, 02:14 AM   #10
I got my WE417A yesterday, and surely gave them a try last night...
Well, they are very good, of course. They might be better in almost everywhere than Raytheon & Amperex. Extension, details, control, texture, dynamics.... all are better, but no "WOW". And it's never the case on the advertisement: "417A WE sounds many times better than the 5842 Raytheon... "
Under quiet ambiance & careful listening, I can hear WE is better, but "many times better"?
Do I need hearing examinations?
And, I'm so tired of comparing things that way. It makes me listen to the same thing repeatedly. It's pathetic, I'm not a reviewer
Proof again, I don't think it's wise to chase famous tubes. They might be good, but the C/P is quite low. Never again.
Confused, datasheet of 417A/5842Hide this!Advertise here!
WTT: One Telefunken EF804 tube for one WE 5842/417A GordonW Swap Meet 0 15th April 2008 02:00 PM
Testing 5842 / 417a satelitis Tubes / Valves 1 23rd September 2007 04:36 PM
I'm looking for 417a/5842 Preamp Schematic without any Transformer, any suggestion ? calico88 Tubes / Valves 7 31st March 2007 07:46 PM
Which valve, 5842 (417A) or 6H30 eeka chu Tubes / Valves 1 30th October 2005 12:08 PM
Substitute for 5842/417A Peter Menting Tubes / Valves 14 10th December 2003 09:55 AM
