Neutrik XLR for Umbilical
Old 16th August 2006, 10:10 PM   #11
kevinkr's Avatar
CPC connectors are pretty inexpensive, the problem is you usually have to buy contacts separately in quantities of 100 per, and even the plated tin ones aren't too cheap. Some vendors do sell them with the requisite contacts included.
I am sure a lot of XLR connectors would work fine voltage wise, but they were not designed for this duty. I use some XLR already in my system for audio and aes digital and sure wouldn't want to mix them up with lines carrying power.
"To argue with a person who has renounced the use of reason is like administering medicine to the dead." - Thomas Paine
Old 16th August 2006, 11:14 PM   #12
On Hiatus
SY's Avatar
While we are at connecting PSU and (pre)amps what is in your opinion better, just to house transformer in other box or to rectify filter and stabilize in one box and transfer to the other (maybe with some additional pasive filtering)?
Generally, I put the raw supply (transformer, rectifier, filter caps) in the remote box and regulator (or additional passive filtering) close to the signal circuit.
"You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is."
Old 17th August 2006, 06:46 AM   #13
pred is offline pred  Switzerland
I have the same thoughts myself but thanks for confirmation SY The only problem for me in this case, when you look for connectors, is most are rated for AC (at least power ones) so it is difficult to know if they are ok.
Pred
Old 17th August 2006, 08:51 AM   #14
On Hiatus
SY's Avatar
All true, but if you use something with a high AC rating, the DC rating, though unspoken, will be fine. I use surplus Amphenol round connectors, but you can also use octal plugs and sockets. They aren't as bulletproof as the Amphenols, but certainly there's no issue with DC voltage up to 500V.
Old 17th August 2006, 02:20 PM   #15
jackinnj is online now jackinnj  United States
jackinnj's Avatar
you can still find 8-pin octal male chasis mounting and 8-pin cable connecting units. easy to cut the holes with a Greenlee.
Neutrik XLR for UmbilicalHide this!Advertise here!
This Connector for an Amp Umbilical? pjanda1 Tubes / Valves 4 9th January 2009 09:24 PM
Design of umbilical cord Rafal Chip Amps 16 9th September 2008 01:33 AM
Umbilical Power Connectors Pathmark Pass Labs 1 16th July 2007 05:16 PM
Umbilical Supplies rtarbell Parts 1 9th March 2006 10:47 PM
umbilical for BrianGT kit waltona Chip Amps 11 26th April 2005 06:00 PM
