Need help for HV section Design
Old 15th August 2006, 12:19 PM   #1
Algar_emi is offline Algar_emi  Canada
Algar_emi's Avatar
Default Need help for HV section Design
Hi. I want to confirm my design before I buy these expensive transfo and choke. I need a 450-470Vdc supply for my current tube phono preamp project. I want to use a tube rectifier.
This is the front end of the power supply. It is followed by a voltage regulator that set the HV at 420V, tehn a serie of CRC filter. This section is working fine.
My preamp circuit will sink between 5-10ma max.
Please check the following schematic and confirm my parts choice. Thanks for any help or suggestion you can provide.
Here the parts specs and my calculations:
Needed HV: 470-450Vdc at the input of the first HV reg that will regulate at 420V.
The tube rectifier 5Ar4 needs a heater supply of 5Vac, 1.9A.
Transfo selected:
Hammond 273DX, 350-0350V, 90ma, FIL SEC: 5V,2.0A
Choke Selected:
Hammond 157G, 30H, 40ma, 596 ohms, 400V
HV Calculations:
350V * 1.4142 = 495V - 17V drop into tube rectifier = 478V before the CLC filter.
I did a simulation using the Power Supply Designer and using this transfo + tube rectifier specified + CLC filter indicated, I got about 470V at the output.
All the others transfo are too low or too high. I choose the lower rating HV secondary (90ma) to reduce the trasnfo regulation over voltage as far as possible.
This tube rectifier is meeting the HV requirements. It is rated for 550V. And it is easily available.
See the schematic below
Old 15th August 2006, 12:29 PM   #2
Algar_emi's Avatar
And the result of the Power Supply Designer simulation.
The traces are for V Caps C1 and C2 (Final)
Old 15th August 2006, 01:24 PM   #3
rjtpeters is offline rjtpeters  Netherlands
Looking at the simulation, i think its possible to improve the voltage step of the supply. It shows some overshoot.
DHT rob has written an artikel on how to make simulations with psud2, however this is in dutch.
Bas Horneman has translated this into english, and the text can be found in his diymagazine, issues christmas 2005 and 2006 1st quarter. (http://basaudio.net/diymag.htm)
good luck
Old 15th August 2006, 01:35 PM   #4
Algar_emi's Avatar
But is the choice of transformer correct?
Will the filament secondary rated at 5V, 2A be sufficient for the 5AR4 that is rated at 5V, 1.9A? Is itn't to close?
What is the impact of this overshoot at startup?
Old 15th August 2006, 01:39 PM   #5
Giaime is offline Giaime  Italy
Giaime's Avatar
Send a message via MSN to Giaime
The question is: what kind of phono preamp needs 450Vdc?
Old 15th August 2006, 01:54 PM   #6
Algar_emi's Avatar
It is a Jadis JP-80 Clone (don't ask ). It has a two stages HV regulation that will bring this HV down to about 400V, then using multiple CRC stages it comes down to about 300V at the 12AX7A tubes.
Old 15th August 2006, 02:45 PM   #7
Chris Daly is offline Chris Daly  Australia
The heater current available from the transformer in this simple AC configuration should be OK , avoid capacitors across the heater. Startup is the critical time as you point out.
You could measure resistance..er if any ,across the heater filament when cold to then
anticipate current draw. A seperate transformer feeding the heater might be a better long term answer. Also try the William Snyder idea of a suitably rated( voltage) diode in parrallel with the choke acting similar to a low value cap but with better defined switch characteristics. A rectified ground return assembled with a 1000v full wave bridge using AC poles as inputs ie one for audio and the other for DC paths with + and - then connected to actual ground provides some nice isolation and is similar in practice to
isolation benefit arising from dedicated ground planes.
Hope this helps / Chris
Old 15th August 2006, 03:40 PM   #8
Algar_emi's Avatar
Interesting idea to use a rectifier bridge to insulate ground return. I'm using star ground.
Here my latest simulation. I changed the transfo impedance to more realistic value, and I changed the LC values. Now the voltage goes up faster without overshoot.
I'm still waiting to get a respond from Hammond with the actual transformer parameters (offload voltage, winding resistance, etc) to input the correct values into the simulation. I'm using estimated values for now.
Old 16th August 2006, 02:14 AM   #9
sorenj07 is offline sorenj07  Germany
sorenj07's Avatar
If I were you, I'd buy the transformer and make some measurements to enter into your simulation, because they can have a pretty big impact (I speak from experience). Buy the transformer and measure winding resistance, then plug it in and measure unloaded voltage on the secondary. With this information you can estimate the transformer's regulation as well as have lots of detailed information to make your simulation a lote more accurate. If you do do this, and post the measurements, I'll design you a nice cheap capacitor-input choke filter with solid state rectification, assuming you don't mind the "sound" of 1N4007's
Old 16th August 2006, 02:59 AM   #10
Eli Duttman is offline Eli Duttman  United States
1N4007s are VERY noisy. UGH!! The UF4007 is a REASONABLY priced part that directly replaces the 1N4007 and it's MUCH quieter. Also, it's possible to totally squelch the switching noise of the UF4007. Search the Bottlehead Forum archives over on AA for RRSF.
Eli D.
Need help for HV section DesignHide this!Advertise here!
Multi Section Cap....diy? redrabbit Tubes / Valves 4 20th July 2007 06:02 PM
DAC with digital section only??? kimschips Digital Source 4 1st August 2005 07:26 AM
ono mc section patriz Pass Labs 7 23rd December 2003 12:14 PM
Copyright ©1999-2017 diyAudio
