| diyAudio Sponsor | ||
Is there any triode spice models that can be used in Circuit Maker 2000?
What spice engine CM is using and what models? |
#2 |
the spice models I need:
ECC88(6DJ8) ECC81(12AT7) 6N3P(2C51) I got all of these models, but I can`t use them in CM 2000. |
#3 |
I have circuitmaker 2000, and this works for me
* 6DJ8 Spice 3F4 model .SUBCKT X6DJ8 P G K Bp P K I=(0.06867321543e-3)*uramp(V(P,K)*ln(1.0+(-0.03262478644)+exp((7.453794563)+(7.453794563)*((3 1.84399594)+(-13.80505589e-3)*V(G,K))*V(G,K)/V(P,K)))/(7.453794563))^(1.37713474) C1 G K 3.1E-12 C2 G P 1.4E-12 C3 P K 0.18E-12 .ends X6DJ8 another version *Vacuum Tube Triode (Audio freq.) pkg:VT-9 (A:1,2,3)(B:6,7,8) .SUBCKT X6DJ8a 1 3 4 B1 2 4 I=((URAMP((V(2,4)/31)+V(3,4)))^1.5)/120 C1 3 4 3.1E-12 C2 3 1 1.4E-12 C3 1 4 0.18E-12 R1 3 5 10E+3 D1 1 2 DX D2 4 2 DX2 D3 5 4 DX .MODEL DX D(IS=1.0E-12 RS=1.0) .MODEL DX2 D(IS=1.0E-9 RS=1.0) .ENDS X6DJ8a 12AT7: *Vacuum Tube Triode (Audio freq.) pkg:VT-9 (A:1,2,3)(B:6,7,8) .SUBCKT X12AT7A A G K * ANODE MODEL BLIM LI 0 V=(URAMP(V(A)-V(K))^ 1 )* 0.0037 BGG GG 0 V=V(G)-V(K)--0.5 BRP1 RP1 0 V=URAMP(-V(GG)* 0.09869 ) BRP2 RP2 0 V=V(RP1)-URAMP(V(RP1)-0.999) BRPF RP 0 V=(1-V(RP2)^ 1 )+URAMP(V(GG))* 0.1 BGR GR 0 V=URAMP(V(GG))-URAMP(-(V(GG)*(1+V(GG)* 0.012937 ))) BEM EM 0 V=URAMP(V(A)-V(K)+V(GR)* 45.093 ) BEP EP 0 V=(V(EM)^ 1.4 )*V(RP)* 0.00000863 BEL1 EL1 0 V=URAMP(V(EP)) BEL EL 0 V=V(EL1)-URAMP(V(EL1)-V(LI)) BLD LD 0 V=URAMP(V(EP)-V(LI)) BAK A K I=V(EL) * GRID MODEL BGF GF 0 V=(URAMP(V(G)-V(K)--0.5 )^1.5)* 0.00012 BG G K I=V(GF)+V(LD) * CAPS CAK A K 0.0000000000004 CGK G K 0.0000000000023 CGA G A 0.0000000000016 .ENDS X12AT7A don't have anything for the 6N3P Other models I do have are at: http://home.netcom.com/~wb2jia/tubes/spice.txt http://home.netcom.com/~wb2jia/tubes/spice2.txt http://home.netcom.com/~wb2jia/tubes/spice3.txt http://home.netcom.com/~wb2jia/tubes/spice4.txt |
#4 |
in any of these programs you should take the Model and back into the curves in the RCA tube handbook (or other). The Koren models work well but they are in need of adjustment of some of the variables to acurately portray what's cookin down there in ECC83 land.
| Trying to learn Circuit maker | Ryssen | Everything Else | 33 | 3rd November 2011 07:21 PM |
| Circuit Maker <<questions>> | bogdan_borko | Solid State | 23 | 24th January 2011 10:31 AM |
| Another 3f4 spice triode model: 5718 submini triode | wa2ise | Tubes / Valves | 0 | 5th September 2008 04:31 AM |
| Spice models | Grahamm | Tubes / Valves | 7 | 19th December 2006 01:36 PM |
| circuit maker library help... | Flavio88 | Solid State | 1 | 2nd September 2006 04:08 AM |
| Page generated in 0.07755 seconds (75.01% PHP - 24.99% MySQL) with 10 queries |
