diyAudio Sponsor
Old 8th August 2006, 04:34 PM   #1
Tyimo is offline Tyimo  Hungary
Default TubeCad's Hybrid amp question
Hi!
I would like to ask the tube experts about the attached schematic:
-what is the correct kathode resistor values or/and how can I calculate it?
Thanks and greets:
Tyimo
Old 8th August 2006, 04:58 PM   #2
leadbelly's Avatar
I'm not a tube expert but I think this might help: JB biases the 6GM8 with 187 ohms in his 24V Aikido.
Aerodynamics are for people who can't build engines. Enzo Ferrari
Old 8th August 2006, 05:46 PM   #3
Giaime is offline Giaime  Italy
Giaime's Avatar
Send a message via MSN to Giaime
Due to the higher power supply voltage, I would expect something between 220 and 270ohm.
Old 9th August 2006, 08:33 AM   #4
Hi!
Thanks a lot for the help!!
BTW, I would like to ask about that 9pin Aikido pre:
How many output voltage has it?
Greets:
Tyimo
Old 9th August 2006, 11:39 AM   #5
Fuling is offline Fuling  Sweden
Be aware that the ECC86 (6GM8) might not be capable of driving power Mosfets high enough in frequency. My attemps to get a similar circuit going failed miserably due to the high input capacitances in the mosfets, even when whey are connected as source followers.
Give it at try, but keep this in mind.
Choosing the smallest possible Mosfet might help.
Old 9th August 2006, 03:32 PM   #6
Hi again Fuling!
Thanks, I know this driving problems already. I would use anyway some E88CC. But it is the future....
For me the choke loaded source follower is the "must"!
Don't you know the output power calculation formula yet??
See you on the OTA thread!
Greets:
Tyimo
Old 9th August 2006, 04:26 PM   #7
Hi Tyimo!
I wonder if E88CC works well at such low voltages.
ÓTOH, if you´re going to build a choke loaded follower you cannot use direct coupling and once you´ve put a coupling cap there you can build a decent driver stage with good tubes operating at whatever voltage they need.
My early experiments with hybrid amps all sounded dreadful because of whimpy driver stages, use a tube with low plate resistance that can handle plenty of current, you´ll need all the current you can get to feed the mosfet´s capacitances.
Power calculation formula, hmm, lemme see...
If you ignore stuff like saturation voltage and losses in the choke, just divide your rail voltage by 1,414, square the result and divide by the load impedance.
Max current? As much as the gear can handle...
Old 10th August 2006, 06:15 AM   #8
Hi Fuling!
First: thanks a lot for the output power calculation formula!!
Second: I agree with your oppinions about the hybrids with low voltage whimpy driver stages
I think I would use something like the Pathos TT, but maybe it would be even better to use Mads K's BOSEWA preamp!!
We made a test with my SEWA +BOZ and SEWA+REMUS tube pre and you will not believe, but the BOZ was better!
Please visit the OTA thread for further discourse!
Greets:
Tyimo
Old 31st August 2006, 10:20 PM   #9
I´ve been thinking a bit about the circuit in the first post.
It appears that a lot of my shortcomings with ECC86 and mosfets was due to low grade test equipment rather than bad circuitry, but I still doubt that an ECC86 can drive a mosfet easily.
The rescue might be an additional follower based on Jfets, more precisely a cascoded White follower. Input capacitanse close to zero and very low output impedance, seems to me like the perfect thing to squeeze in between the tube and the power Fets.
Have a look at this schematic (by wrenchone):
http://www.diyaudio.com/forums/attac...amp=1135983661
It might look complex, but since direct coupling to the tube would be possible we can remove the bias network and the input/output caps. Suddenly the component count is down to a half.
A three stage CCT might not be as elegant as a two stage CCT, but amps that doesn´t make it to 20kHz ain´t much fun either...
In a while I´ll start building an active crossover based on similar buffer circuits, so there´s no reason for me not to order some extra Jfets and try this one out.
I have friends within reasonable driving distance that has much better test equipments than I do
PS: I have a 30VA toroid transformer with 13 + 13+ 7V secondaries, perfect for a complete 6,3V and 35V PSU!!!
Old 1st September 2006, 08:17 AM   #10
Ryssen is offline Ryssen  Sweden
Ryssen's Avatar
Interessting..what will happend if you leave the bias network there?Any side effect´s?
Regards Åke
Question about changing a hybrid Nixie Tubes / Valves 17 15th August 2006 11:25 PM
hybrid rectifier question dr.strangelove3 Tubes / Valves 17 4th October 2005 01:28 AM
Question about a hybrid PSU design reaction Tubes / Valves 2 10th October 2004 11:45 PM
Page generated in 0.10029 seconds (80.60% PHP - 19.40% MySQL) with 11 queries
