| diyAudio Sponsor | ||
Hello All,
I am building a small tube amplifier where I need a B+ voltage after bridge rectification and CLC of 200 - 250 VAC. I cannot find a transformer manufacturer who makes a 75 - 0 - 75 VAC or single 150 VAC secondary. If I used a transformer with a 150 - 0 - 150 VAC secondary and only connected up one leg of the secondary, would there be any problems? Note that this transformer will also have a filament secondary. |
#2 |
With a 150-0-150 transformer, you don't need a 4-diode bridge. Just ground the center tap ("0"), and use two rectifier diodes in a full-wave configuration. Connect the anode end of a rectifier to each of the 150 windings, and tie together the cathode ends (marked with a line). At that same point connect your CLC filter. Depending on several factors, you should get somewhere just over 200 volts. There are many references to power supply design if you do some searches.
If you are a newbie, I hope you will spend some time looking at the permanent high voltage safety thread here.
Brian |
#3 |
Thank you. Yes, I did not think about a full wave rectifier circuit. I will try this because I have a 125 - 0 -125 VAC transformer already in the breadboard circuit. Actually, this voltage is on a very low end of circuits I have built.
#4 |
If you're working on building a PSU then I can't recommend Duncan Amplification's PSU Designer II software more. You have to make careful measurements of your PT, unloaded voltages, and (unplugged) impedances of all the windings, but once you do, it's great.
http://www.duncanamps.com/psud2/index.html |
| LM3875 Transformer Connection | Kinnja | Chip Amps | 10 | 18th January 2011 03:31 PM |
| need help on transformer secondaries connection | atenolol50 | Tubes / Valves | 6 | 26th September 2008 08:52 AM |
| tubelab SimpleSe power transformer connection question | dubdub | Tubes / Valves | 10 | 12th September 2008 01:30 AM |
| paralell connection of transformer ofr ucd180 | bcrazy | Class D | 0 | 1st January 2007 12:46 PM |
| Transformer connection for BOSOZ | Yochim | Pass Labs | 3 | 6th September 2002 05:45 PM |
| Page generated in 0.07080 seconds (71.48% PHP - 28.52% MySQL) with 10 queries |
