| diyAudio Sponsor | ||
#101 | |
BTW, not to be a turd here, but 6x5=30 can certainly be argued about. Like if I'm using a base 7 system and you're using base 9.... |
#102 | |
#103 |
Sorry Joel, but this time you missed SY's point.
He is saying "post something with substance, and proof, not just opinion". Yet I posted both substance and electronic fact (as well as other smart folks like you have done), and yet you say "You missed the point, Gabe". So for both your sakes, and for the last time: I use polypropeline capacitors for interstage coupling in most applications. They... uh.. my amps sound clean and distinct. But when I replaced the interstage coupler of one stage with a copper foil paper in oil capacitor (exact same value), bass got a little deeper and highs got somewhat grainy. Steve bench provides the proof with a Lissajou pattern which displays the nonlinearities that explain what I hear. Replacing all the interstage caps got more deep bass and more grainy highs, but much more detail in the mids. It was nice overall, but I cannot justify paying 16 dollars per cap versus 75 cents. Cheaper carbon resistors on the other hand should give nothing more than noise. That is also substantiated with experiment and measured fact. One can indeed measure the noise of a carbon resistor versus metal film. Yet, some more fact: noise tends to mask undesirable and objectionable sound (as ANY recording engineer, acoustician, and otolaryngologist will tell you). So of course some will say that they think the noisy carbon resistors sound better, because noise is masking what they don't like to hear. As for musicians, I was just showing that those ancdotes are all over the place and different for different people and experiences. Did I miss the point? Purely your opinion for the sake of... "discussion"? And the statement that you "just like to argue" is not substantiated? How about posting a statement like "If you're into the raw Hammond look. Somebody send the man a spray can!"? It was obviously designed to do just what it did you clever little Vulcan. Provoke me to reply. I will only say this: I haven't gotten any complaints yet! Gabe
Gabe CGV Electronics Home of the CGV-300B amplifier on a budget |
#104 |
Now I'm a 'Vulcan'?
Will you look at all the entertainment you people are getting??? And for FREE!!! We should all send Jason $1, just for this thread alone. anyway, Gabe, I have done the old switcheroo dozens of times also. I did not hear the things you describe. Now can we let it go? |
#105 |
Gabe, how did you determine that substituting a copper foil paper in oil (nice poetry, that!) caused the sonic effects that you describe? Did you listen, do the substitution, then listen again?
#106 |
i can recommend an ear specialist
#107 |
diyAudio Moderator Emeritus
Several people have referred to Steve Bench's excellent page on capacitor non-linearities.
No component is perfect if we look deeply enough. The question seems to me, to be: Is the difference SIGNIFICANT? Now that's the argument Perhaps I am not well enough read, but no one has so far shown me the effect of changing a coupling capacitor type - in terms of measured overall response. I know we're getting into that dark area...... Finally an admission and a little hypocracy: Although I'm not on the "orange drops bandwagon", I have still chosen the best reasonably priced caps for my current amp. Why? Because it gives me more confidence, and is another thing I don't have to worry about ![]() This is the closest I come to superstition
#108 | |
On Hiatus
who is gonna stop me if i do both |
#109 |
Halojoy,
I do believe you are shamelessly posting to reach enlightenment
#110 |
On Hiatus
i am enlightend
but it takes one to know one |
| metal film or carbon film? | Roushon | Parts | 36 | 17th October 2011 10:33 PM |
| metal film resistors or carbon? | leitmo | Tubes / Valves | 2 | 28th June 2008 11:14 AM |
| riken resistors: carbon comp or carbon film? | jarthel | Parts | 0 | 20th October 2006 02:00 AM |
| Res Survey:....... Carbon film ...or... Metal Film ...............?? | nina | Chip Amps | 13 | 14th April 2005 01:46 AM |
| Carbon film vs metal film resistors in a stepped attenuator? | G | Tubes / Valves | 17 | 22nd August 2004 01:22 AM |
| Page generated in 0.14027 seconds (81.92% PHP - 18.08% MySQL) with 11 queries |
