| diyAudio Sponsor | ||
Hi
I am looking for 8 and 9 pins PBC mount tube socket dimension. Anyone have one? Thanks Doan |
#2 |
Well, sorta...
There are several versions especially of 9-pin PCB sockets. Here is what I use: 9-pin: 0.413" radius pin circle, 36 degrees between pins (or, a radial array of 10 pins with one missing). 0.076" hole diameter, 0.15" pad diameter Octal: 0.500" radius pin circle, 45 degrees between pins (or, a radial array of 8 pins with none missing), 0.100" hole diameter, 0.25" pad diameter These seem to work with most of the sockets out there. The 9-pins vary by a mm or so but usually can be persuaded to fit this PCB pattern. Be careful about pin numbers (numbered counterclockwise from the top (socket side) of the PCB). I have these in a library for Eagle CAD if you're interested. You can download it here: http://www.pmillett.com/diy_cad_programs.htm Pete |
#3 |
Thanks Peter
it's help me a lot, that is the best imformation i can go ... thanks a lot Doan |
#4 |
Here is another:
http://www.desmith.com/NMdS/Electronics/soculator.html |
#5 |
One more ... Cool...
Thanks Doan |
#6 |
I'm not sure how accurate these drawings are - but this Headwize design has some Express PCB designs with 9-pin sockets. This should at least point you in the right direction.
http://www.headwize.com/projects/cavalli2_prj.php |
#7 |
Thanks a lot, kstagger
according to pete's website. I will make myself a library in cad... That would be easy to any PCB. I am gonna test it first, If it was good, I am more than happy to share with anyone. Thanks Doan |
| tube socket sale | tubesocket | Vendor's Bazaar | 21 | 11th November 2008 01:36 AM |
| tube socket PCB library or dimensions | PRNDL | Tubes / Valves | 3 | 1st May 2007 07:05 PM |
| ExpressPCB 9-pin tube socket drawing | DragonMaster | Everything Else | 0 | 9th April 2006 11:10 PM |
| Tube socket wanted. (help where) | Hojvaelde | Tubes / Valves | 3 | 22nd June 2005 12:29 AM |
| Anyone have a mini 7 pin tube socket lying around? | Skitch72 | Swap Meet | 2 | 8th March 2005 03:47 PM |
| Page generated in 0.08301 seconds (72.64% PHP - 27.36% MySQL) with 10 queries |
