diyAudio Sponsor
Old 14th September 2006, 05:25 PM   #11
Fuling is offline Fuling  Sweden
And from below:
Old 14th September 2006, 05:26 PM   #12
With cover (unfinished):
Old 14th September 2006, 05:28 PM   #13
And the PSU. The toroid and the heatsink/tagboard makes the HV supply, the rest is for the heaters:
Old 14th September 2006, 05:30 PM   #14
My matching active crossover, built with discrete JFETs on tagboards. 12dB/oct 90Hz Linkwitz-Riley.
Old 14th September 2006, 05:32 PM   #15
Inside view:
Old 14th September 2006, 11:35 PM   #16
pmillett's Avatar
Maybe this is a little late since you've already built the amp... but you might find this interesting:
http://www.pmillett.com/Books/lockhart.pdf
An example of extreme cathode and screen grid feedback...
Pete
Old 15th September 2006, 10:01 AM   #17
Thank you for the very interesting url!
Old 15th September 2006, 09:50 PM   #18
I believe I´ve forgotten to post schematics of the power amps:
Edit: In the real version there is no voltage divider for the screen grids, the grids goes straight to B+ through 1,5kohm carbon composite grid stoppers.
tweeter extremes...which end of the spectrum to choose? thadman Multi-Way 2 7th December 2006 03:58 AM
OPT at frequency extremes mashaffer Tubes / Valves 5 23rd July 2005 11:54 PM
I'm taking the plunge! zagisrule! Solid State 3 2nd May 2004 10:29 PM
BJT vs MOSFET - taking the best of both Bakmeel Solid State 46 11th September 2003 06:56 PM
Page generated in 0.08802 seconds (73.22% PHP - 26.78% MySQL) with 11 queries
