OPT Project for EL84 SE
Old 7th August 2006, 08:27 AM   #21
Toober is offline Toober
Send a message via Yahoo to Toober
What do you think about DC coupled amplifiers? Maybe like this.....
Anyway, I ask only for my general culture, I am decided to build the modified RH84 design.
Old 7th August 2006, 08:43 AM   #22
Mas Penk is offline Mas Penk  Indonesia
Default Direct Coupled
Direct Coupled offer advantages of capacitor weakness (best coupling cap is no cap). But during building you must pay attention since motorboating behaviour could be an issue. not to mention the risk when driver tube fails, that could bring the output tube to death too.
I have built one EL84 direct coupled, it sound almost like RH84 but RH84 has more Bass while DC-EL84 has brighter (more open?) and detailed sound.
Penk
Mas Penk
Old 7th August 2006, 08:56 AM   #23
Miles Prower is offline Miles Prower  United States
Miles Prower's Avatar
I tend to favor getting rid of as many coupling capacitors as possible. Every time you add another AC coupled stage, you're also adding a phase shifter as well as a high pass filter. Those extra phase shifts can compromise stability under feedback, and can also compromise bass performance. I also like DC coupled cathode follower final grid drivers to eliminate distortion under transient overdrive, get the slew rate up, and force a few extra watts out of a class AB1 design that can slip partially into ClassAB2. I did an 807 design with a nominal 26.5W with a v(i)= 45Vp-p (just puts the 807 Vgk(max)= 0V). With 35W Hammonds, I can push that to over 30W because the cathode follower drivers can get that little bit extra out of it by taking the grids positive. Of course, this also requires fixed bias, which automatically results from the DC coupled cathode followers.
I also like lots of extra "head room", and the design maxes out when the OPTs saturate, not when any stage clips.
Of course, I do high fidelity, so very little of that will apply to a gee-tar amp.
There are no foxes in atheistholes
www.dolphin-hsl.com
Old 8th August 2006, 05:31 AM   #24
TonyTecson is offline TonyTecson  Philippines
TonyTecson's Avatar
I haven't found those schematics you have suggested, but I have something here and here
What do you think about them?
Anyway, does anybody wants to share a OPT project with me? Please.....I already have the lamination (grain oriented, EI 28 mm tongue), it's only missing the project.
Thank you!
i have one, uses a 7/8 inch square stack, on a bobbin for 7/8 inch sq. core...has 5400turns #34 magnet wire on primary, 3 layers, wired in series, then two layers #30 awg for 216 turns paralleled, so this OPT has 5 layers interleaved, for the gap i use file folder cardboard material.. hope this helps...good luck!
planet10 needs your help: Let's help Ruth and Dave...http://www.diyaudio.com/forums/plane...ml#post5010547[B
OPT Project for EL84 SEHide this!Advertise here!
5W EL84 drive EL84 SE Audio_idiot Tubes / Valves 31 31st May 2012 09:38 PM
Help on EL84 / ecc83 SE project -very low volume mcgaag Tubes / Valves 28 8th June 2009 02:11 PM
EL84 DC 10Y Project korneluk Tubes / Valves 5 19th May 2008 06:03 AM
SE EL84 project for my friend akimball442 Tubes / Valves 17 28th June 2007 11:04 PM
Beginners Project: Need a schematics for a small simple EL84 SE (or PSE) amp Erik Johansson Tubes / Valves 2 15th May 2002 12:35 PM
