| diyAudio Sponsor | ||
I've search here and in AA and can't seen to find much discussion on this amp.
thanks for the replies. ps. maybe I was using the wrong search criteria so I wasn't getting good search results.
#2 |
I am guessing you have read Thorsten's article at Thunderstone audio. I have a pair of these, at least a variation. I used the el84 driver. I departed from the Legacy as descibed by TL in a couple of places. I used a cathode resistor (1760 mills 12w) and bypass cap (22u polypro) on each leg of the 300b filament circuit, which is how I think the original Verdier design was implemented, although I added a pair of WE (ultra path) caps (6u GE motor run caps) from each side of the filament to b+ tap of OT. You might note that this implementaion results in different bias on each side of the output tube due to the dc filament supply. I am not sure if it will affect tube longevity, western electric allowed for use of dc on the filaments per their data sheets. I have the filaments polarized oppsite each other on the amps, and rotate the tubes amp to amp periodically. In addition, my psu is nothing special, a clc (small tuning cap, choke, and large cap for main b+, with additional rc for the driver stage. The driver stage needs a pretty smooth dc to avoid hum, so the extra rc stage. This was actually based on advise from TL, since I wasn't going to do the regulated supply thing. The hum level at the speaker terminal is low, about .6-.8mv. I will say these amps sound very good - easy to listen for hours without fatigue!
#3 |
I made the amp using an SV83 driver and changed the bias on the 300B a bit too. I also used Electron One output transformers.
For the power supply, I used an outboard 200mA/500V HP Regulator. The filament supply was onboard and I used a pair of 5VAC Hammond transformers with a hum-pot. I ended up with a small bit of hum - sound was really nice - lots of snap - with plenty of detail and good treble extension. 8ws of power just wasn't enough when listening to AC/DC though! |
| "universal" P-P driver board | tubelab.com | Tubes / Valves | 43 | 6th February 2009 04:55 AM |
| Developing a "universal" tube power supply PCB | Geek | Tubes / Valves | 42 | 15th August 2007 08:10 AM |
| Wanted: Hammond 125E or other "universal" output transformer | Spasticteapot | Swap Meet | 2 | 13th July 2007 11:29 PM |
| Page generated in 0.07791 seconds (70.02% PHP - 29.98% MySQL) with 10 queries |
