| diyAudio Sponsor | ||
Regarding the powerdrive schematic here:
http://www.tubelab.com/powerdrive.htm I notice an ajustable bias supply of -~150V to the gate of the 2sk2700, and a -400V supply via a 10k to the grid of the 813. What is the purpose of the -400V supply? If using 211's instead of 813's, do I still need this supply? |
#2 |
The negative 400 volt supply is there to provide the source for the grid voltage on the output tube. I used a - 400 volt supply because it was easy to make in the 845 amplifier.
The positive 150 volt supply sources the current for the tubes grid in A2. These power supplies MUST be capable of swinging the entire range of possible grid voltages seen by the output tube (bias AND signal voltage). The easiest way to figure these out is to look at the plate curves for the tube used. The negative voltage supply must be enough to completely cut the tube off for the plate voltage used. In my case I need -300 volts to cut off an 845 with 1200 volts on the plate. A 211 can be completely cutoff even with 1250 volts on the plate with -125 volts. I would use a -150 volt supply for headroom. If you are running a lower plate supply voltage you may get by with a less negative voltage. The positive supply must be high enough to to drive the tube deep into saturation. +50 volts should be plenty for most tubes (except the 811A and the 833A). I used +150 volts because it is easy to make from US power (a bridge rectifier on an isolation transformer).
Too much power is almost enough! Turn it up till it explodes - then back up just a little. |
#3 |
The main reason I want to build a true Triode amplifier is because I find the powerdrive circuit so facinating, its one of the few complex circuits I understand!
#4 |
Thanks for the explination, but I'm not sure I understand this... in the powerdrive schematic, the -400 supply is used to bias the 813?......what does the "bias supply" do?
#5 | |
The control grid of most tubes must be "biased". This means that a negative (with respect to the cathode) voltage must be applied to the grid to control the current through the tube. If the negative voltage is not there the tube will run "full throttle" and usually self destruct. Think of this as the gas pedal in your car, except that the spring holds the pedal to the floor and you must pull it up to slow down. The negative voltage pulls it up. If the negative voltage supply is not there the 211 will have a short unhappy life (car floored all the time). It is also likely that the tube failure could blow up a lot of other parts (car crash). If your knowledge of vacuum tube circuits limited, and this is your first amplifier, please don't start with a 211 amplifier. The voltages used in a 211 amp are instantly lethal in an accident. Amps of this nature are hard to construct, expensive, and the chances of success are slim for an inexperienced builder.
#6 |
This is my first post in the forum, also a newbie in electronics (both tube & SS). please kick me if I ask too many rubbish question. I see that you RC couple the input of the source follower and DC couple the cource to the 845, wouldn't it be easier to also RC couple the source to the 845? The reason is that I had build a 45 which is very much similar to your simple 45, B+ is ~320Vexcept that it is RC coupled and cathode LED bias and 75Hchoke plate for the 6c45p at 150Vp, -2.2V bias and zener cathode bias for the 45. I am thinking of trying out a source follower betwee the two tubes to see if it makes any difference in fidelity. I only have IRF820 in hand. I am thinking of doing some thing like that, I will bias the Mosfet with a 5V zener from B+ (with a series 330K resistor)to the gate, then I will pop the drain of the source to the B+ and connect the source to the ground and souce connect to 45's grid via a coupling cap of 0.1uf and replace the grid resistor of 45 to 20K. Please kick me if it's complete rubbish, Cheers
Audio_Idiot |
#7 |
This is my amp currently.
For the main 1100 V to the OPT, I use a c/tapped, mercury vapor PSU, CLC, with NOS PBC paper capacitors and a NOS PCB oil choke. Coupling caps are Russian teflons. So, I want more power. How much % more power will I get if I drive the 211s into A2? I was thinking of using a 45 driver and the powerdrive circuit, or a 5881 pentode dc coupled to the grid of the 211... |
#8 | |||
It just might. Quote:
With MOSFETs, the Zener between the gate and source isn't for biasing. It's there to protect the gate from excessive voltages. You'll need an extra bias pot for setting the MOSFET's Q-Point current. |
#9 | ||||
#10 |
i just wanna walk out on stage with girls going down on my 211' s, while I sweep bach at high volume.
| Help understanding the PowerDrive circuit anaylsis | Bitrex | Tubes / Valves | 1 | 22nd July 2009 04:15 AM |
| NAD and their PowerDrive technology | rtarbell | Solid State | 3 | 25th August 2008 07:10 AM |
| PowerDrive Circuit for 805 (+ve grid bias) | snoopyma | Tubes / Valves | 7 | 17th August 2006 04:18 AM |
| Page generated in 0.15086 seconds (85.81% PHP - 14.19% MySQL) with 11 queries |
