#11 | |
Sy has cited more sources of info (which you should read), but even the original citation reads at the bottom of the first page: "These techniques can be extended for higher output voltages and/or currents by using better high voltage transistors or cascoding or paralleling (with appropriate emitter ballasting resistors) several transistors". Take this information, make a proposed design and ask for comments on the design. Sheldon |
| Tube SE amplifier with 6P3S (russian tube) | danzup | Tubes / Valves | 46 | 12th April 2012 08:35 PM |
