diyAudio Sponsor
Old 24th July 2006, 08:39 PM   #1
Default Bass guitar preamp
Hi!!!!
I'm looking for a tube bass-preamp schematic. Does anyone have a circuit ? I searched for half hour and didn't find anything.
Thanks!!!
Old 24th July 2006, 11:07 PM   #2
Send a message via ICQ to Mikael Abdellah Send a message via MSN to Mikael Abdellah
I am searching for info on the exact same subject. So far I haven't found much. Im looking to build a VERY simple preamp, preferably with tubes.
Old 24th July 2006, 11:30 PM   #3
Why don't we try and figure something out together? The only thing I've come up with so far is a 6N1P and BUF634. I can't find much info on signal levels and such. Do you have any idea what the normal signal level from a passive bass pickup is? The gain of the 6N1P is 33, and from what I can figure out that seem to be roughly 15dB.
Old 25th July 2006, 02:52 AM   #4
Hi!!!!
I dont know how much I can help to design a tube amp. What I can offer is some tube manuals/datasheets, my father used to build tubes stuff. But he dont know about hi-fi, only radio amps......
I Think that I have lot of 12ax7 tubes for the project.
I will use an active bass guitar so I need both inputs. I dont know how to design a preamp for bass, I dont know nothing about impedances of bass pickups.
If there is anything i can do, tell me. I also have some tube manuals, schematics, but they're like 30 years old.
thanks!!!!
Old 25th July 2006, 07:32 AM   #5
Just tell me what kind of features you want. Im going to buy my first bass guitar in the next 2 weeks. I have never played any kind of string instrument before, so you probably have a lot of things to teach me about what kind of effects and tone controllers would be nice to have. My first idea was to just build a small gain stage with a low mu (gain) tube and just a buffer but it looks like the signal might me a bit high to start with. I was aiming for just a bit over normal home stereo equipment line level but assuming closer to 2-300mV from the guitar Im afraid i will blow up the opamp or buffer on the output. I cant do any measurements before I get my bass.
Old 25th July 2006, 07:44 AM   #6
You could try to build the one in the picture. It's a very simple schematic and sounds very good indeed, I recently built one myself. The original Alembic unit has two identical channels (which are modelled after Blackfaced Fender amps). I built a preamp with only one channel, and added "bass-shift" and "treble-shift" functions like present in the Mesa Boogie Bass400. I have built that preamp as well (a long time ago), and didn't like it much.
I did redesign the powersupply with DC heater supply, and B+ with a overkill amount of capacitance (had a bunch of caps lying around).
The preamp is easy to build and sounds super, I would say a fine candidate for a first project (if you treat the HT with the appropriate amount of caution).
Oemptempa petoempetapap
Old 25th July 2006, 07:47 AM   #7
And this is the Mesa Boogie Bass 400 schematic:
Old 25th July 2006, 08:13 AM   #8
Looks nice and simple but since you use both halfes of the 12AX7, wont that produce way too much gain? Have you measured you "maximum" output signal voltage?
Old 25th July 2006, 08:36 AM   #9
Hello Mikael,
I am not much of an EE guy (rather ME) so I didn't measure anything, but this schematic is built by Alembic so I just considered it a finished design. I did hear someone say there is a mistake in the schematic somewhere.
But you are right, when using my (active) bass, the output is quite "hot", I am thinking of adding a 6db pad.
Old 25th July 2006, 01:07 PM   #10
thank you all for the replies !!! interesting schematics.
I think I will build the preamp stage of this one:
As a power amplifier, I have a LM3886 gainclone,... do you think that I can use the output of the master pot as output to feed the gainclone?
thanks!!!
bass guitar preamp billr Tubes / Valves 19 26th May 2012 03:36 PM
2-band bass guitar onboard preamp phil mailloux Instruments and Amps 71 23rd August 2011 08:55 PM
Making and onboard bass guitar preamp Skywalker83 Parts 7 3rd December 2008 08:42 PM
6N1P or EF86 for bass guitar preamp? Mikael Abdellah Tubes / Valves 14 10th March 2007 08:01 AM
Hybrid bass/guitar preamp Mikael Abdellah Solid State 10 16th February 2007 10:16 AM
Page generated in 0.11460 seconds (72.64% PHP - 27.36% MySQL) with 11 queries
