diyAudio Sponsor
Old 22nd July 2006, 08:51 PM   #1
rossdt is offline rossdt  Italy
Default KT88 and push-pull ultra-linear
What do you think about this quiescent point for KT88 in push-pull ultra-linear operation?
Values for TWO tubes - Class A
DC Plate Voltage = 395 V
DC Screen Voltage = 395 V
Cathode Bias Resistor = 200 ohms
Peak AF Grid-to-Grid Voltage = 70 V
Zero-Signal DC Plate Current = 170 mA
Zero-Signal DC Screen Current = 12,5 mA
Effective Load Resistance, Plate-to-Plate = 5600 ohms
Screen Tapped at 40%
I use Cathode Bias without capacitor
Better ideas?
Thanks.
Old 23rd July 2006, 11:39 PM   #2
What I think is that with the values you describe you will get about 30W in Class AB (not Class A) and that you should use separate 400 Ohm resistors on the cathode of each KT88, rather than a common 200 Ohm cathode resistor. All the data sheets and application notes are quite clear on this point.
Ian
Old 24th July 2006, 09:28 AM   #3
Really?
Then, how do I do to work in class A?
Which quiescent point?
Thanks.
Old 24th July 2006, 11:27 AM   #4
jane is offline jane  Norway
jane's Avatar
2 x 100mA into a 5600 ohms p-p load will give you ~30W class A.
Check the plate dissipation; I'll suppose 100mA will bring you close to the limit.
PmaxA = [(Iq x 2)^2 x Rpp/4] / 2
Life is hard - Then you die.
Old 25th July 2006, 04:54 AM   #5
Since the topic of cathode resistors is brought up, why do some designs share the resistor between 2, sometimes even 4 tubes?
VTL Manley 807 push pull ultra linear mosfets Tubes / Valves 5 11th May 2009 09:03 AM
KT88 Push-Pull denny9167 Tubes / Valves 9 21st January 2008 07:54 PM
EL84/6BQ5 Ultra-Linear Push-Pull Recomendation diegot Tubes / Valves 17 5th April 2007 11:41 AM
Schematic needed PL519 Push-Pull Ultra-Linear amp mario2005 Tubes / Valves 0 15th May 2006 08:41 PM
KT88 push pull Hojvaelde Tubes / Valves 5 10th November 2005 06:51 PM
Page generated in 0.08273 seconds (73.26% PHP - 26.74% MySQL) with 10 queries
