829B Based Amp
829B Based Amp
Old 18th April 2009, 05:18 PM   #11
volos is offline volos  Russian Federation
http://lynxaudio.narod.ru/articles/Lynx_VTA39.pdf
Very Best!!!
Old 12th March 2012, 11:26 AM   #12
Vikt0r is offline Vikt0r  Ukraine
Send a message via ICQ to Vikt0r 829B Based Amp
With regard to the last post - I seriously doubtful about the "verybestness" of Lynx's overkill design. You must know the russian saying "what is too much that is not healthy".
If anyone is still interested about the 829b - here is some schematic (sorry - it's drawn in russian, but i would comment it), aimed to build a truly two-bulb amp. The driver stage uses a 6H8C/6SN7 biased with a blue led. The output stage uses a single GMI-6 (kinda russian pulse-mod of 829B) for both channels, connected in pentode mode, with anode feedback (small amount) and stabilized at 250 volts 2nd grid (that is common). Strictly fixed bias (16v), not even a small cathode resistance. The OT is for 5K primary resistance. The amp sounds really amazing, very open and natural, all those SE triode lovers (that's what I have been )- forget your triodes, they're garbage
It is WORTH to try anyway once somebody's around a hard decision. Feedbacks are welcome.
Old 27th July 2013, 10:30 AM   #13
lotehk is offline lotehk  United States
Default Where do you get those diodes???
Old 27th July 2013, 10:35 AM   #14
Hi.
Please let me know where I can acquire the LED1 and the D1= KC630 and the
other zener diode D2= KC620
lotehk
Old 27th July 2013, 03:35 PM   #15
Blaireau is offline Blaireau  France
Blaireau's Avatar
Wink 829B
"Maybe the 829 is not the best tube for your first tube projectů " The best way to use 829B and other tubes with common screen grid is to parallel electrodes of both halves, an use a couple of tubes into your PP instead of only one. This would definitely solve your problems with UL PP.
http://constructions.f6fkn.com
Old 28th July 2013, 01:50 AM   #16
farhun is offline farhun  United States
KC620 is 120v KC630 is 130V zener diodes. Max current is about 50ma if I'm not mistaken.
From the original post: ...and stabilized at 250 volts 2nd grid (that is common)...
829B Based AmpHide this!Advertise here!
829B SE Comments???? coldcathode Tubes / Valves 51 12th February 2010 05:08 PM
829B as LTP? DrewP Tubes / Valves 10 17th June 2009 08:00 PM
829B tubes for audio? webercarbmann Tubes / Valves 6 16th February 2002 11:34 PM
