diyAudio Sponsor
Old 27th July 2006, 05:27 AM   #51
dnsey is offline dnsey  United Kingdom
Do it the practical way if you prefer:
Take a (say) 100W lamp, and put the diode in series with it.
Estimate the light output: is is equivalent to a 50W or a 25W lamp?
(Undoubtedly, it's 50W).
QED
In fact you could do the same thing properly, using your iron and heating a known volume of water. The output of the iron is then easily calculated. If (as I'm sure it will) it puts out 25W - less a bit for losses - and (as contended) consumes only 12.5, file that patent quickly!
Old 27th July 2006, 06:01 AM   #52
A further 'thought experimental' solution:
Connect a pair of parallel diodes back-to-back in series with the iron. AC is now restored. If each diode is supplying the current for 12.5W, where's the other 25W coming from?
I'm still having trouble soldering the diode in series with the AC line -- the soldering iron stops working when I cut the wire to splice-in the diode. What am I doing wrong?
You have to solder the diode onto the wire before cutting it, of course
I had a similar problem when I owned only one (Antex) iron. The element had soldered terminals, which was fine until it needed replacing...
Old 27th July 2006, 01:52 PM   #53
AKN is offline AKN  Sweden
Enjoy good sound
AKN's Avatar
Carlos,
I was wrong about page 45 in manual, page 57-58 is correct regarding PDF manual.
You will find it here:
http://assets.fluke.com/manuals/45______umeng0400.pdf
It will tell how to set up Fluke 45 correctly for this purpose, altogether with curvforms and everything.
Did you measure according to my previous post, #48?
And...Please tell us that you will get 25W after reading manual.
/ Anders
Old 27th July 2006, 02:38 PM   #54
poobah is offline poobah  United States
poobah's Avatar
I used to play a mean prank in the shop sometimes. When people were done using the solder pot, they would naturally unplug it. When no one was looking I would take the plug for the solder pot and hang it with prongs immersed in the cooling solder -
Old 27th July 2006, 02:41 PM   #55
Poo, you're a devil.
regards Andrew T.
Old 27th July 2006, 02:50 PM   #56
poobah's Avatar
I guess... something about the irony of it all just struck me a certain way... like a snake eating its' own tail.
Old 27th July 2006, 03:12 PM   #57
janneman's Avatar
Location: Where Germany, The Netherlands and Belgium meet
Originally posted by refference
Hi HarryDymond ,
NOTHING WRONG with my DMM , because it’s a FLUKE
TRUE RMS MULTIMETER model 45 ( bench top ) ,
5 ½ digits .
If you have a high-quality DMM like this , try to measure
the TRUE RMS voltage , after half-rectified , at the input
of a 50 Watts iron solder , before contest my measure .
When we are talking about AC voltage , the ONLY value
that has any interest is the RMS value , because is it that
execute the job .
My answer to the quiz , is 12.5 Watts , yet .
Regards ,
Carlos
Most multimeters are calibrated for RMS value of a sine wave. Clip half of it, or use a squarewave with the same amplitude, and all indications become wild guesses. It takes a pretty sophisticated mm to actually calculate the RMS for different wave forms to be correct with different so called "crest factors" which is the ratio of peak voltage to RMS. As an example, music has very high crest factors: very low RMS but relatively high peaks. So, a peak rectifier meter calibrated in RMS will indicte way too high.
Anyway, I digres. The point is that most mm are calibrated and designed with sinewaves in mind. If you have a cheap mm, that uses internal single rectification and indicates the peak value, calibrated in RMS, you wouldn't see any difference if you clip one side of the input sine. Or, depending on the polarity, your indication goes to zero if you clip the wrong polarity.
Jan Didden
/Another new issue: Linear Audio Volume 3!
Old 27th July 2006, 03:29 PM   #58
jneutron's Avatar
Jan Didden
Correctamundo, Jan.
Carlos:
Here's the relevant part of the figure 4.3 from the fluke manual that shows how this meter reads various signals.
Examine the table closely. It says that for a true rms reading of 1 volt, you put in either a 1.4 volt (0 to pk) full sine, that same 1.4 volt sine but full wave rectified, or....a 2 volt peak half wave rectified sine..
What you are doing the equivalent of, is putting in a 1.4 volt half wave sine. So you are providing only ~70% of the equivalent voltage to give the 1 volt reading as per fluke's table. The meter will read 70.17% of the actual waveform.
Care must be taken when trying to interpret the readings.
As I stated, by inspection the answer is half power. Poobah has also calculated correctly on a lobe by lobe basis.
Cheers, John
Old 27th July 2006, 03:32 PM   #59
Enjoy good sound
AKN's Avatar
Janneman,
I agree with you, but.....
Fluke 45 is capable of True RMS, the problem here is how he use it. Fluke can be setup to take into account DC potential or not therefore Carlos get wrong readings in this perticular setup.
Edit: Wrong readings for Carlos calculations.
/ Anders
Old 27th July 2006, 03:38 PM   #60
poobah's Avatar
Well... has anybody ACTUALLY meaured it? The claims thus far would imply that they were using perfect diodes. In which case, I would like to know where they are buying them.
Yet another Lowther cab quiz brownie Full Range 17 3rd June 2009 03:51 PM
Interresting Quiz. Which tube is this? Radioman62 Tubes / Valves 5 28th December 2008 12:41 PM
Pop Quiz keantoken Solid State 3 15th June 2008 10:05 PM
Group Quiz JRKO Music 6 23rd January 2005 05:14 PM
math quiz- input z triode amp tenderland Tubes / Valves 7 23rd November 2004 06:05 PM
Page generated in 0.12331 seconds (73.71% PHP - 26.29% MySQL) with 11 queries
