diyAudio Sponsor
Old 21st July 2006, 08:57 PM   #21
jneutron's Avatar
Originally posted by poobah
This is getting complicated rapidly.
Nah..
What about the thermostatic device? If it's one of those magnetic styles that use the curie temperature to disconnect the heat path to the tip, that is indeed an issue. It would try to maintain the proper tip temperature, but dwell below temp would (of course) be longer..ie, the duty cycle would be extended by the lower power capability.
How much energy is involved in the magnetic domain conversion?? Or do we consider it as a lossless system, thereby introducing an unknown variance..
Stand orientation is another issue. What angle, what is the convection cooling rate...that needs room temp number..and the density, so the altitude of the workshop is an issue, as well as the barometric pressure. And, the barrel diameter. Is the tip conical or does it have flat surfaces...
Cheers, John.
PS..heard new riders of the purple sage last night..they are good...
Almost duct taped the sound board operator to a door of a bathroom stall, man did he butcher the vocals..(as in..what vocals)
Old 21st July 2006, 09:10 PM   #22
poobah is offline poobah  United States
poobah's Avatar
Now consider if the iron had been used for any period of time, on symmetric AC, and had established true bi-directionality in conduction properties of the filament. How long would it require for the expected adirectionality of the filament to develop when using the diode?
Old 21st July 2006, 09:19 PM   #23
dnsey is offline dnsey  United Kingdom
But from what I've read, once burned in, a length of wire has superior conductivity properties for ANY signal, symmetrical or assymetric (otherwise, far from improving its sound, the resulting non-linearity of a cable would result in increased distortion).
The real question is whether the iron is rated at 50W when brand new or after x hours of running in.
Old 21st July 2006, 09:27 PM   #24
poobah's Avatar
You're dismissing the pioneering works of B. Alderdash (a Brit BTW), N. Onsense and others...
Old 22nd July 2006, 04:45 AM   #25
Tony is offline Tony  Philippines
Tony's Avatar
Send a message via Yahoo to Tony Send a message via Skype™ to Tony
can't believe that this thread is now 3pages long, so mr threadstater, would you mind telling us who passed your quiz?
Placebo medicine works best when the doctor believes in it too. Next best is when the doctor is good at pretending to believe in it.DF96
Old 22nd July 2006, 05:09 PM   #26
You all failed! Have to take into account the sag in the power line voltage when plugged in. 24.5 Watts unless you bought one of those $500 silver power cords, then 24.6 Watts.
No cheating allowed by putting the iron on the floor so the electrons role down the hill easier!
Don
Ohms Law V = I R
Old 22nd July 2006, 05:19 PM   #27
Of course, some irons have an SCR temp control, so one will either get 0% power with a diode or 100%, depending on polarity. And some better irons have an xfmr, in which case you will get smoke too! (and 1000% power)
Don
Ohms Law V = I R
Old 22nd July 2006, 05:19 PM   #28
KBK is offline KBK  Canada
Originally posted by tubelab.com
DON'T try this on ANY device that uses a power transformer. The resulting DC offset will cause saturation in the transformer, followed by smoke in the transformer. The smoke will not stay in the transformer for long!
Would there not also be just a touch of the 'inductive collapse' coming down the pike as a thermal buildup issue? Just musing a bit, gotta morning coffee in me (so far) , being adventerous.
"Never forget that only dead fish swim with the stream." -- Malcolm Muggeridge.
"Truth cannot be brought down, rather the individual must make the effort to ascend to it." -- Jiddu Krishnamurti
Old 22nd July 2006, 05:21 PM   #29
You're dismissing the pioneering works of B. Alderdash (a Brit BTW), and others...
N. Onsense , isn't he from Pakistan or was that India?
What color is this soldering iron, anyway?
Old 22nd July 2006, 05:30 PM   #30
Send a message via AIM to DigitalJunkie
Now the REAL question is,Which sounds better?
Joints soldered with an iron with a diode
or
Joints soldered with an iron without a diode
Yet another Lowther cab quiz brownie Full Range 17 3rd June 2009 04:51 PM
Interresting Quiz. Which tube is this? Radioman62 Tubes / Valves 5 28th December 2008 01:41 PM
Pop Quiz keantoken Solid State 3 15th June 2008 11:05 PM
Group Quiz JRKO Music 6 23rd January 2005 06:14 PM
math quiz- input z triode amp tenderland Tubes / Valves 7 23rd November 2004 07:05 PM
Page generated in 0.11569 seconds (80.45% PHP - 19.55% MySQL) with 11 queries
