diyAudio Sponsor
Old 21st July 2006, 03:22 PM   #11
AKN is offline AKN  Sweden
Enjoy good sound
AKN's Avatar
Just half of time conducting, I vote for 25W.
calculating ac voltage is done (peak voltage) / (sqrt2)
In this case half of period would be taken away (same peak) so half power as result.
/ Anders
Old 21st July 2006, 04:15 PM   #12
jane is offline jane  Norway
jane's Avatar
Default Re: a quiz about AC power
Originally posted by vax9000
Here is a quiz about your knowledge of AC power.
Hi vax9000!
If you want to, you can log on to my uVAX II and write a Fortran program that solves the quiz.
$ telnet veiset.net
Username: SCOTT
Password: TIGER
http://www.veiset.net/
Old 21st July 2006, 05:23 PM   #13
vax9000 is offline vax9000  United States
Hi Jane,
You UVAX II might someday need my MSCP SCSI controller @ www.mscpscsi.com.
Old 21st July 2006, 06:02 PM   #14
jneutron's Avatar
Between 25 and 50.
It will of course, depend on the resistance coefficient of the element. The colder the element, the lower the resistance.
Without the coeff, one is unable to get the correct value.
Cheers, John
Old 21st July 2006, 06:21 PM   #15
Enjoy good sound
AKN's Avatar
Originally posted by jneutron
Between 25 and 50.
Cheers, John
Look at this statement from vax9000:
"Ignore the fact that resistance changes with lower temperature"
/ Anders
Old 21st July 2006, 06:27 PM   #16
jneutron's Avatar
oops..
Ah, but I cannot ignore that..
If one wishes to really peak the interest of others, then one should also specify a resistance tempco. THAT makes the problem interesting. A solution which can be arrived at by inspection is not fun at all..
Cheers, John
Old 21st July 2006, 06:31 PM   #17
poobah is offline poobah  United States
poobah's Avatar
The tempco isn't linear (or geometric) though. We would need a baseline filament temp at 50W to have any real fun...
Old 21st July 2006, 06:46 PM   #18
Enjoy good sound
AKN's Avatar
Maybe we should question AC source, Ri and DC potential?
/ Anders
Old 21st July 2006, 08:14 PM   #19
jneutron's Avatar
Buuuuuttt..
One cannot forget the time constant of the element either. So we need the heat capacity, the thermal conductivity average, and the rate at which heat is removed from the system.
Then we can calculate the instantaneous element temperature, it's instantaneous resistance, hence the power draw, then we're cookin...
Simple recursion stuff, actually.
Do we assume the heat transfer mechanism is linear?? That would ruin it, of course..no brainer...
Cheers, John
Old 21st July 2006, 08:27 PM   #20
poobah's Avatar
I 'spose that would depend on whether the iron is in the stand or in use...
This is getting complicated rapidly.
Yet another Lowther cab quiz brownie Full Range 17 3rd June 2009 04:51 PM
Interresting Quiz. Which tube is this? Radioman62 Tubes / Valves 5 28th December 2008 01:41 PM
Pop Quiz keantoken Solid State 3 15th June 2008 11:05 PM
Group Quiz JRKO Music 6 23rd January 2005 06:14 PM
math quiz- input z triode amp tenderland Tubes / Valves 7 23rd November 2004 07:05 PM
Page generated in 0.10863 seconds (77.80% PHP - 22.20% MySQL) with 11 queries
