| diyAudio Sponsor | ||
Would anyone have a schematic they could let me have a copy of please?
Thanks, Phil. |
#2 | |
Cheers, Shawn. |
#3 |
You will not find a schematic. Bill Beard had a policy of not releasing schematics to the public. The present service dept continues the same policy and will not release schematics, so that's it I'm afraid, unless anybody has reverse engineered anything.
#4 |
Email can help you
Regard analog guy |
#5 |
Super Durable Tube Power Amplifier, but already fixed by me !!!
Regard analog guy |
#6 | |
Cool pics of the interior! |
#7 |
I don't have a schematic but I can send you many pics via email.
I fixed it 2 years ago, only switch on-off broken !!! circuit is very good health !!! Regard analog guy |
#8 |
I just bought a non-working P-100 but it looks different than the one in this thread. I think mine must be an earlier version.
The amp has a bias issue on one channel. The amp has a board with pots to adjust the tube bias (see right side of picture below). I believe the board connects to the cathode and then there is a 10 ohm resistor to ground. When I first powered up the amp with full voltage both of the 10 ohm resistors on the bad channel burned out. I thought the problem could be a bad cap in the bias board. Today I replaced the caps and the burnt resistors. I powered the amp up and thought I solved the problem. I had the amp on for about 10 minutes and began adjusting the bias to the .5 volts dc documented on the bias board. When I connected my multimeter to the output side tube on the bad channel I noticed the voltage begin to rise. Before I knew what happened the 10 ohm resistor flashed and it was gone. Any suggestions what to try now? I have tested the tubes and they all test good. |
#9 |
| Upgrading a Beard P100 tubeamp | ronenash | Tubes / Valves | 24 | 9th April 2011 09:23 AM |
| Beard P100 Bias Lights | davehiggins21 | Tubes / Valves | 5 | 13th June 2010 09:14 PM |
| Beard P35 | Jules | Tubes / Valves | 0 | 3rd December 2007 02:03 PM |
| LINK P100 info | Ralphies | Multi-Way | 0 | 19th April 2007 12:10 PM |
| Beard P100 | Tom Smithson | Tubes / Valves | 12 | 18th October 2004 11:00 AM |
| Page generated in 0.11218 seconds (74.93% PHP - 25.07% MySQL) with 11 queries |
