| diyAudio Sponsor | ||
#11 | |
#12 |
.6 ohms in series with the primary will not drop much voltage unless you have a seriously hungry amplifier.
Look for an "Inrush Current Limiter". Some data can be found in the DigiKey catalog. http://dkc3.digikey.com/PDF/T062/1405.pdf If you pick the right size you can get a nice slow turn on (easy on the tubes) and drop 4 or 5 volts in the primary circuit.
Too much power is almost enough! Turn it up till it explodes - then back up just a little. |
#13 |
You might be able to find one in an old SMPS also.
I commonly see them in PC PSU's..usually a little green ceramic looking thing,in series with the line input. I've also seen the larger ones in monitors,and whatnot.Ya might get lucky and find one that works nicely. |
#14 |
Those inrush limiting resistors look promising. I think I've found one, but I have never used them before so please correct me if I'm wrong:
Imax = 1A R (25°C) = 5R R (Imax) = 0.6R This could be used, no? Since the amp won't actually get near 1A continuously (more like 0.75A), I'm guessing the resistance will be a little more than 0.6R under load? OR I could use a 0.47R/25W resistor on each leg of the secondary... but that's the easy way out -- Rolf |
#15 | |
Life is hard - Then you die. |
| Reducing transformer voltage... | 69CamaroSS396 | Power Supplies | 7 | 27th May 2009 08:25 PM |
| reducing voltage | rtill | Solid State | 28 | 16th January 2009 01:45 PM |
| Reducing PSU Voltage | hernanstafe | Parts | 1 | 9th March 2007 05:14 PM |
| Reducing Voltage in a safe way. | darkm4n | Solid State | 106 | 7th March 2004 12:44 AM |
| Reducing output voltage | macce78 | Chip Amps | 16 | 17th January 2004 09:21 PM |
| Page generated in 0.08248 seconds (72.96% PHP - 27.04% MySQL) with 10 queries |
