| diyAudio Sponsor | ||
I have started my first tube amp from the scratch: Just one concern about the circuit…. I would like to ask you about the cathode resistor of the EF86, I found it too high , 100K, reviewing the data from various manufacturers this tube wiring as triode usually has a Cathode resistor of about 2K2, in fact if you see the voltage of the capacitor that is bypassing cathode resistor is rated @ 25V, having a resistor a value of 100K and a current of about 1mA (100V across Rk) the capacitor will explote. Please your comments about this point and please add as much recommendations as you want, I have all the parts right now, the chassis is finished and I will start the wiring this week end.. Thanks in advance to all of you!!!
Jorge |
#2 |
It's a typo, I suspect the correct value was probably 100 ohms. Somewhere online is a Svetlana application note on using a triode-mode EF86 in a low distortion line stage. It would make a great starting point for your application.
Edit - The somewhat similar Mullard 3-3 uses between 82 and 150 ohms on the EF86 cathode depending on speaker and global NFB. |
#3 |
Ooops, sorry JORGETronic. Make that 1000 ohms instead of 100 ohms. I forgot the Mullard uses the EF86 in starvation mode. The line stage I meant is shown below.
#4 |
Thanks for your help in my first amp RDF!!!
Yes I found the same when you mention it, i guess I will try with 2k2 first as this is the value recommended in a couple od data sheets form diferent vendors..... has this amp a classic tube sound?
Jorge |
#5 |
No problem
#6 |
Hi Jorge,
There's been a little talk about the combination ef86 triode / triode-strapped el84 on the decware forum and the conclusion is that the ef86 is a fantastic sounding driver tube for el84, even better than the acclaimed e88cc. A few notes about your circuit though (to be honest I'ld leave it altogether): the output tubes run probably at a voltage of around 225-240V depending on the primary resistance of your opts; that's very low: 280-300V should be better (200ohms cathode resistor or 100ohms, 220-1000µF with a shared cathode resistor = the output stage of the decware zen = gives wider soundstage). Without doing the maths it's also obvious that the ef86 runs at a much too low voltage, better to aim for 270-280V (1,3k cathode resistor, 100µF). For best sound swap the ef86 for it's high quality equivalent e80f, it's as cheap as a normal ef86. If you're interested in building an el84 single-ended I'ld recommend to take a look at decware's pages where you can find the schematics to some of their amps (el84/ecc88 set & el84/ecc83 single-ended pentode). The bonavolta schematic you're planning to build will - when using 1k cathode resistor instead of 100k as stated - certainly work (although it's full of obvious flaws) but if your power transformer has some extra voltage just go for an ef86/el84 like the one I described above or take a look at the Decware website. Also don't rule out el84 pentode, you'll have more power, better attack, highs and lows but miss the midrange forwardness and lushness of the triode-strapped el84. The triode-strapped babies + bill's triode strapping method (see decware forum / t-linespeakers) might be the ideal solution, I'm going that road with my e80cc / triode-strapped el84. Lastly the choice of output tubes is very important (as with all tube-amps), try to find some Mullards (sometimes rebranded as Philips, Valvo) or Matsushita. This makes the difference between a boring sounding versus a magical tap-your-feet amp... Good luck, Simon |
#7 |
Hi Simon
Thans for taking the time to comment, the PSU is almost done, then I will be implemmenting one by one your recommendations, I will start more conservative, as thye original first, this is my first shot!!!! saludos
Jorge |
#8 |
I have finished the amp. there is a terrible oscillation in the el84, i could see sparks from the plate pin to the earth bus soldered in the center of the socket.
The only changes to the circuit were: el84 cathode cap is 1000uF, the same with the ef86, the Rk of the ef86 is 2,2K...... I did not connect the shield of the imput tube, It is necesary?, if yes how? connected to catode? any suggestios?
Jorge |
#9 |
the amp is up and running, just a motor boating noise from time to time.... I would like to get opinions about this implementation, my first implementation..
Jorge |
#10 |
here you can see the ground star do you see any problem there, I have a very strong noise from time to time and I was wondering if Ihave a grounding issue
Jorge |
| 40A 250V Schottky Power Diodes- Has anyone use in Power Amp to replace Diode Bridge? | dtm1962 | Solid State | 10 | 15th September 2011 07:38 PM |
| LTspice tool for power amp power supply component evaluation | andy_c | Software Tools | 2 | 23rd August 2009 05:10 PM |
| Power transformers versus amplifier output power..what is your option? | destroyer X | Solid State | 38 | 9th May 2009 05:23 PM |
| Amplifier 3000 Wats Rms Power + Smps Higcht Power Bestiality | MARAVILLASAUDIO | Class D | 1 | 5th November 2004 04:06 PM |
| power output calculations, rated power and required power output | metebalci | Tubes / Valves | 7 | 22nd February 2004 05:49 PM |
| Page generated in 0.16128 seconds (60.76% PHP - 39.24% MySQL) with 11 queries |
