diyAudio Sponsor
Old 18th July 2006, 03:39 AM   #1
TomWaits's Avatar
Default 6au5gt
I just saw a little collection of NOS 6AU5GT Sylvania's in the old boxes and stamped USA on the glass. I purchased one to take home and fiddle with.
Have you seen any SE or Push Pull designs using this handsome little TV tube? I bet it would make sweet audio? Any comments would be great!
Shawn.
Old 18th July 2006, 05:48 AM   #2
I had some RCA 6AU5GT. they are design as power tube, but I can't found any schematic on web. maybe you should design by yourself, I think its not diffcult to built ibut dosent mean sounds good.
Sam
Old 18th July 2006, 05:55 AM   #3
Fuling is offline Fuling  Sweden
Anyone know anything about a 6AV5GA?
The Edcor meets the 6AV5
Edit: Ooops, 6AU5 and 6AV5 ainīt exactly the same thing, but close.
Old 18th July 2006, 06:13 AM   #4
http://www.pmillett.com/tubedata/beam_power_tubes.pdf
try this you can built a nice amp
Old 18th July 2006, 02:45 PM   #5
tubelab.com's Avatar
I found one 6AU5, and tried it during the 6AV5 experiments (same pinout) mentioned in the previous post. I didn't push it hard enough to find its limits because I only had one and it looked well used.
You should be able to use these in a generic triode wired SE amplifier, but I don't know how much B+ you can get away with since the screen grid is only rated at 200 volts. I think this tube would work well in screen driven P-P applications. This seems to be the best application for a 6AV5.
The DeHaviland 845 SE amplifier used a 6AV5 for the driver in early units and then switched to a 6AU5, because "it sounds better".
Too much power is almost enough! Turn it up till it explodes - then back up just a little.
Old 18th July 2006, 04:26 PM   #6
TomWaits's Avatar
Default Beam Power
OK Tubelab, testing shows best result in Push pull? Inside the pdf from P.Millett's site "Beam Power Tubes" by O.H.Schade(thanks sam8888ysl ) I found the basic set up(see attached).
I cracked the pdf with Photoshop and tried to open up the diagram so if you need to scribble on top, you will have more room.
Am I getting somewhere?
Shawn.
Old 18th July 2006, 04:28 PM   #7
TomWaits's Avatar
Default Input Phase Inverter
If I remove the transformer couple set up from the previous schematic can I attach something like this as preamp section?
Again, am I even close here?
Shawn.
Old 18th July 2006, 04:36 PM   #8
astouffer's Avatar
A 6AU5 triode strapped is excellent for driving large transmitting tubes like the 845.
Old 18th July 2006, 04:37 PM   #9
TomWaits's Avatar
Default Power supply
Do we really need B+ of 300 and 400 volts? Can this be reduced to a single supply?
Would the circuit function better with -negative bias instead of ground?
I read in the pdf previous that the Beam Tube circuits requires only 10% or less in feedback?
Give me some more feedback and I will try to draw a proper schematic when I get back home tonight. My goal is small power with low distortion.
Thank you very much for the input so far, perhaps we have a new amp brewing here?
Shawn.
Old 18th July 2006, 10:32 PM   #10
TomWaits's Avatar
Default Sylvania Data Sheet
I extracted the data from PMillett's posted Sylvania 1951 guide on the 6AU5GT ( these are the ones I have access to) and reduced in to a one page data sheet.
Does this help the situation? It is rough and I have a higher rez so email me and I'll send it to you or brouse it youself by downloading from P.Millett's site. It is in the 1951 Sylvania pdf.
Shawn.
Also, here is a link to a bigger image.
Page generated in 0.09762 seconds (79.29% PHP - 20.71% MySQL) with 10 queries
Copyright Đ1999-2012 diyAudio
