diyAudio Sponsor
Old 17th July 2006, 03:01 AM   #1
Default wanted RIAA schematic
I had built some tube amp, but never built RIAA. I want to built a tube RIAA amp. Now I still heave some 5670.5687.5965.6922.5963.WE407A.6BK7B.5844...... and I prefer simple is the best, so, anyone can give me some idea, Thanks, Sam
Old 17th July 2006, 03:10 AM   #2
jackinnj's Avatar
I have an Audio Research SP-8 -- the RIAA section is very, very acurate -- you can find a schematic on the Audio Research database: http://www.arcdb.ws/ Also www.tubecad.com has some very good schematics.
Unfortunately Tritschler who wrote a very nice article in AudioXpress 2003 with a passive tube RIAA preamp seems to have gone off the air. I bought two boards from them and they were very, very acurate indeed, but radio silence for months.
Old 17th July 2006, 03:27 AM   #3
Geek's Avatar
Have you searched the forums? There's quite a few good ones here already.
Old 17th July 2006, 09:01 AM   #4
thanks, I had already find some schematic but, they seem very copmlex, dosent any simple design? like simple RC.
Old 17th July 2006, 09:26 AM   #5
Geek's Avatar
Giaime has a very nice simple "passive" phono stage. I don't know if it's simple enough for you:
http://www.giaime.altervista.org/mypreamp_eng.html
I have an active one here:
http://members.dowco.net/canadageek/...hono-Stage.png
Both are one tube/channel designs.
Old 17th July 2006, 09:42 AM   #6
Have a look at www.dddac.de and look for Phono dude (tube portal & projects ->tube projects -> item6)
Here you can find a detaild description of a good RIAA amp.
Best regards
Old 17th July 2006, 09:52 AM   #7
thanks, but I cannot link to the web
Old 17th July 2006, 10:14 AM   #8
Giaime is offline Giaime  Italy
Giaime's Avatar
Send a message via MSN to Giaime
Very honoured to be mentioned some little adjustment in some component values are needed in my circuit, I will post it later.
Old 17th July 2006, 10:45 AM   #9
Giaime's Avatar
Corrections done, refresh your browser page if you still see the old schematic. This is the good one:
Old 17th July 2006, 11:01 AM   #10
You might check out
Http://www.hagtech.com/images/cornet2schem.gif
They offer a circuit board for this. The reviews are quite good also.
Wanted RIAA stage with 6SN7 sam8888ysl Tubes / Valves 20 30th July 2011 11:03 AM
Wanted Mordaunt-short MSW20 Schematic Wanted simon dart Subwoofers 0 22nd May 2009 08:19 AM
Easy DIY RIAA-preamp wanted. kmj Solid State 13 18th March 2004 07:42 AM
Page generated in 0.11829 seconds (80.00% PHP - 20.00% MySQL) with 11 queries
