PL36 PP Amplifier 22W Full construction details
Old 15th July 2006, 07:30 PM   #1
mario2005 is offline mario2005  Serbia
Default PL36 PP Amplifier 22W Full construction details
So, today I desing and built :
PL36 PP Amplifier 22W class A , with 6N7 and ECC82
The PL36 pentode was originally intended for use as a line output, (or horizontal deflection) valve in television receivers.
Full construction details and my experience with PL36 PP Amplifier can be posted here, or sent to email if you need that.
Best regards
Mario2005
Old 15th July 2006, 07:57 PM   #2
Giaime is offline Giaime  Italy
Giaime's Avatar
Send a message via MSN to Giaime
Post here Mario, please,
I'm also working on a EL36PP, but in triode mode, should give 10W in class A.
Tell us more about your design!
Old 15th July 2006, 09:45 PM   #3
Default Schematic
Schematic
mario2005
Old 15th July 2006, 09:52 PM   #4
On Hiatus
SY's Avatar
The anode and screen voltages appear to be 100V over the maximum ratings (250V). Caution!
"You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is."
Old 15th July 2006, 10:18 PM   #5
I start with 450V and all work perfect!!!!!!!!!!!!!!
Now 400V.
I have 3 diferent Philips Tungsram and Telam Four matched tubes.
Tungsram is the best.
PL36 is beter then 6L6 and similar with EL34 !!!!!!!
this is maximum from PL36 .
The prototype amplifier has been running almost non stop since It was built. more then 10 hours .
regards
mario2005
Old 16th July 2006, 01:02 AM   #6
Tubes4e4 is offline Tubes4e4  Germany
Tubes4e4's Avatar
Hi Mario2005,
neat design, but what is the objective of PL36 in (horribly non-linear) pentode mode, when you can get the same power from extremely linear triode strapped PL36 PP?
See this link.
SY: Yes, PL36 is used even more grossly over specs in this design. But they will stand it. I suspect spec sheet design center ratings were really given with TV deflection duty in mind.
Tom
If in doubt, just measure.
Old 16th July 2006, 04:09 AM   #7
Geek is offline Geek
Geek's Avatar
You beat me to it.
The E/PL36 is an extremely tough tube. It'll take 22W before plate glow
I have no idea why it wan't used in RF service
Old 16th July 2006, 09:22 PM   #8
triode mode PL36 PP and 380V
Old 16th July 2006, 10:13 PM   #9
Giaime's Avatar
My take... of course not exceeding EL36 maximum values
10W in class A, DF = 10 with the OPT that I'm waiting
No need for feedback to tame errors: since there aren't any.
Old 16th July 2006, 10:25 PM   #10
Tubes4e4's Avatar
If the driver/splitter will work as required (I didnīt check this), you will get about 20W Po in class AB1 using this output stage setup, delivering about 8W in pure class A which should be more than enough for sweet listening.
Damping factor will be about 3,5 w/o any gNFB applied, which is decent already. Nevertheless I would suggest to use about 6dB of gNFB, but nothing more than that is needed. Certainly not the 20dB you mention in the circuit diagram, which probably is just a left-over from the previous plain pentode (errr ... beam power) version.
For EL36/PL36 triode strapped plate curves have a look here, although this plot will not cover the actual Pd you are running your PL36s at. But you can easily prolong the curves
Tom
PL36 PP Amplifier 22W Full construction detailsHide this!Advertise here!
Full throttle construction of amplifiers destroyer X Solid State 251 25th January 2011 07:54 AM
GU50 SE Amplifier class A , with 6SN7 Full construction details mario2005 Tubes / Valves 118 14th August 2010 06:33 PM
Fountek & Peerless Design - Construction Details Inside! soundengine355 Multi-Way 12 6th August 2008 03:14 AM
Proyect with PL36 and N2P (Russian ECC83) tortxu Tubes / Valves 0 24th February 2008 10:04 PM
amplifier construction Spence38 Solid State 0 14th February 2008 01:48 AM
