I am thinking of building one of this: http://www.tubecad.com/2006/04/27/ai..._amplifier.png
I am wondering if the output caps can be omitted if I use an output transformer. Thanks for the help. |
#2 | |
Aerodynamics are for people who can't build engines. Enzo Ferrari |
#3 | |
can you suggest an output transformer from the hammond range that is suitable for the aikido headphone amp? thank you |
#4 |
Can't see how you could use an output transformer with the aikido circuit other than in a parafeed (capacitor coupled) arrangement which would be a bit pointless in this case since you would still need the output caps
#5 |
Requires an airgapped OPT, so Im not sure low end iron will beat capacitor coupling of similar cost. Consider using oil motor run capacitors for budget coupling caps as another alternative. From correspondence:
Be sure your foil hat has a good low impedance ground. |
#6 |
Thanks for correcting me. I was thinking of the attached schematic and thought that the capacitor was only needed for DC blocking for the High-Z output. I also thought non-airgapped transformers were suitable for this service if the DC current was low enough, but it sounds like that's not the case.
#7 |
Fine iron may well beat fine caps, but, there are many fine iron proponents who dont feel Hammond quite qualifies. Also, finding an OPT whos DCR will set the bias for an optimal operating point may be tricky.
#9 | |
#10 |
I canīt do the math, but to my eye the circuit first published would seem to work nicely with a Lundahl 1660SE/18mA. Is there something that would make this a bad choice in the Aikido output stage?
Edit: and the second one would do witout a coupling cap, if you don't need the high z output. |
| Aikido as a headphone amplifier (Output transformer groupbuy) | Bas Horneman | Headphone Systems | 63 | 1st March 2012 04:58 PM |
| Aikido Transformer recommendation | Original Burnedfingers | Tubes / Valves | 0 | 14th March 2007 10:51 AM |
| Noise on Aikido output | Andypairo | Tubes / Valves | 35 | 7th January 2007 09:01 AM |
