diyAudio Sponsor
Old 13th July 2006, 01:43 PM   #1
alejo is offline alejo  Argentina
Default Avo Ct-160
Hello, IŽn very very happy !!!!!
I find one AVO CT-160 in very good conditions, without rayons nor dust, all clean.
But the main power plug cord is missing. I search info in web, the plug is plessey 3 pin (type F) iden use in military UK equipament, and in radio Racal R17.
I try find it but dont lucky, ....,.
EC8010 I see you live in UK and you use one AVO CT160, please if you want to write. email is
Email address removed to avoid SPAM. EC8010
Old 13th July 2006, 04:06 PM   #2
Family_Dog's Avatar
Send a message via ICQ to Family_Dog
Congratulations on your Ct-160!
I also have one, but it has definitely seen better days. The Meter was not working and the Set Neg Grid Bias pot is open circuit, apparently a very common fault on these portable units and of course new pots are unobtainable. Is your CT-160 working correctly otherwise?
My unit is also missing the mains cord and I had to hard wire a length of cabtyre cable in for an AC mains cable.
I think there is a schematic and further notes for this unit on the Duncsan's web site.
Vintage Tube Hobby Group:
http://groups.yahoo.com/group/vintage_tube/
Old 13th July 2006, 04:13 PM   #3
Yes, all in it work ok. I use mini cocodrile lead for connect to wall.
Old 13th July 2006, 07:08 PM   #4
Family_Dog see here for your grid pot:
http://www.vintage-radio.net/forum/s...ad.php?p=22507
Old 13th July 2006, 07:26 PM   #5
Family_Dog's Avatar
Yep, I had seen that before. Crowthorne Tubes in England also has a replacemnet kit for the pot as I recall, as well as for the Meter Movement. Very helpful fellow!
In the meantime I was lucky to find an AVO 4, and then another, and even yet another... as well as an AVO 3 that could probably be fixed.
I had to strip the CT-160 meter out for one of the AVO 4 testers, while the latest one I was fortunate in obtainiong is in just about mint condition.
Old 13th July 2006, 07:52 PM   #6
EC8010 is offline EC8010  United Kingdom
EC8010's Avatar
alejo: I'll email you, but I've removed the address from your post to avoid you being deluged by SPAM.
The loudspeaker: The only commercial Hi-Fi item where a disproportionate part of the budget isn't spent on the box. And the one where it would make a difference...
Old 14th July 2006, 01:08 PM   #7
thanks for replys,
I see for news connectors, more safe, IEC Plug an others...
in nexts days I promise photos.
Old 14th July 2006, 11:31 PM   #8
316a is offline 316a  England
316a's Avatar
Hi ,
If you can't find the correct cable , remove the socket and fit either a similar shrouded socket or if the mains plugs in your country are small enough to fit with the lid closed , simply solder and tyrap a mains lead in . I fitted an IEC socket to mine . There are a few things that will need checking . The roller switches will probably need a thorough clean . Also there is only one calibration pot inside , if the meter does not reach FSD using the mains taps , this will need to be adjusted . Once the meter can reach FSD , test a valve . During the test , measure with a DVM on the breakout panel between grid and cathode and check this correlates with the setting on the grid pot . Set the current pots to zero then check at various settings up to -45V . Avo used a strange log-lin-log pot which is unobtainable , this can burn out or go out of spec . You may find that at various grid settings the grid volts dial will be way off what is measured , if this is the case then always measure on the breakout panel with a DVM . Hope this helps
cheers
316a
Page generated in 0.08932 seconds (75.51% PHP - 24.49% MySQL) with 9 queries
