diyAudio Sponsor
Old 12th July 2006, 02:23 AM   #1
rwellerson's Avatar
Default PP Amp using 811A
Hello
Anyone with exp in this 811A tube in PP for an audio amplifier?
Ricardo
Old 12th July 2006, 02:54 AM   #2
Gotham Audio Corp made one to use as a record cutting amp that is a little tricky to build but sounds very nice. Use a 4-5k output transformer. Here's a link to the schematic:
http://www.triodeel.com/gothamp.gif
I have one that I built and I love it; I just never got arount to building a mate to it for stereo.
Daniel
Old 12th July 2006, 03:12 AM   #3
mod_evil's Avatar
Send a message via MSN to mod_evil
Hi Ricardo,
What you will supply with the 811A?
Can you put in here more informations?
You will supply subwoofers or a full-range speakers?
Thanks,
Felipe.
Brazilian Tube Amp Builder.
Old 12th July 2006, 03:33 AM   #4
Default Class A2 or Class AB2 ??
You can always implement the Altec 1570 topology. MagneQuest
could supply you with the magical centre-tapped choke that
is the essence of the driver stage for PP 811A.
The 1570 will be expensive to implement. It will also deliver a
full 150W and run out at 900V at several hundred mA of current.
You could attempt to implement at lower and saner voltages.
You'd definitely be breaking new ground by doing a PP 811A.
I dont know of anyone whose ever attempted it. The closest I've
seen is a PP SV572-10 that was featured in Glass Audio years back.
811A's are cheap and easy to come by.... You could also use
572Bs. Ask yourself if you really need all this power? A 20W
single ended 845 amp might not only be sufficient, but pleasantly
satisfying.
-- Jim
Old 12th July 2006, 03:41 AM   #5
SY's Avatar
I've done two 811A p-p amps. The first, maybe 25 years ago, was a fairly conventional transformer-coupled p-p. I wasn't happy, mostly because the tubes really wanted to see a higher plate load, and high power 10-15k transformers are not easily available, nor would I expect them to have good bandwidth.
The second, a recent project, was a class B p-p direct drive ESL circuit using a center-tapped choke. That worked very well, but the plate voltage limitations did not allow anything above background music levels.
Class B zero-bias with a nice high current drive seems to be the key.
“Listening to records is like ****ing a picture of Brigitte Bardot.” - Sergiu Celibidache
Old 12th July 2006, 10:52 AM   #6
I owned several Altec's in the past and was not happy with the bass response. I'm wondering if the driver stage had something to do with it. I also had a 807 PP Bogan with a similar driver stage and lack of bass.
I sure do like the look of the 811's.
Old 12th July 2006, 02:19 PM   #7
rwellerson's Avatar
Thanks a lot folks...
I can see we have some hidden experts in these exoteric 811A matters here!
Well I was wondering about an input signal tube e.g. 12AT7 feeding something like a pair of EL84 or even a pair of EL34 doing the phase splitter to a pair of PP 811A...
I think this is perfectly possible to implement and just imagine a pair of these relatively cheap triodes yelding around 100 to 150w...
What do you think about this approach?
Any ideas about the circuitry?
Power is just like money: it's never enough!
[ ]s
Ricardo
Old 12th July 2006, 02:29 PM   #8
mod_evil's Avatar
Ricardo,
How much are you paying for the 811A in Brazil?
Thanks.
Old 12th July 2006, 09:29 PM   #9
As far as bass response.... I did a Parafeed, single-ended 811A.
I have fantastic bass. In fact, better than my 845 amp. The
PF transformer is rated at 10W and has a nickel core.
I think you run into trouble dealing with high-Z output transformers combined with the high levels of standing current. Further, conditions at the driver (which needs to cope with grid current), might further compound the problem already presented by the DC current in the output transformer...
Old 12th July 2006, 09:43 PM   #10
klm1 is offline klm1  United States
klm1's Avatar
Talking Yeah 811's in ...massively parallel...
Million watt amp!! sooooo Kewwwwllll!!!!
Ok; check out tubelab.com's site here
for his totally cool 811A project(yew are 'da man, tubelab)
Please, please, please do not miss his safety info; also on our
site here under tubes.
also check out antique radio classified links here
there are some very nice, helpful guys out there-join the club,
get acquainted, take your time, learn some good stuff!
Now, about that massively parallel design !
some like it hot;"the biggest mistakes are made by those who make assumptions!" Graham Maynard
811a Class A2 jim Tubes / Valves 73 10th March 2012 02:38 AM
811a Opt GK Tubes / Valves 20 19th May 2008 01:08 PM
811A amp Class A2 MartinV56 Tubes / Valves 9 19th October 2007 04:34 PM
811 vs 811A? Ryssen Tubes / Valves 6 12th March 2007 10:11 PM
811A in P.S.E or P/P exurbia Tubes / Valves 8 22nd February 2004 11:37 PM
Page generated in 0.10788 seconds (78.63% PHP - 21.37% MySQL) with 10 queries
