diyAudio Sponsor
Old 11th July 2006, 05:42 PM   #1
Ryssen is online now Ryssen  Sweden
Ryssen's Avatar
Default Eqvalents to 6888
Need an eqvalent to the pentode 6888,octal 6,3v heaters,are there any?
Regards Åke
Old 11th July 2006, 06:13 PM   #2
Giaime is offline Giaime  Italy
Giaime's Avatar
Send a message via MSN to Giaime
Couldn't find any, sorry. What's the need for a 6888?
Probably old equipment, isn't it? Otherwise, if you are building something, better to switch to more available types.
This thread might be of interest:
http://www.diyaudio.com/forums/showthread/t-19368.html
Old 11th July 2006, 06:27 PM   #3
VT67 is offline VT67  Belgium
VT67's Avatar
Apparently the E180F is a possible substitute. I have a few NOS 6888 at hand (Bendix and Sylvania). Same question as Giaime, why do you need them?
Old 11th July 2006, 06:40 PM   #4
Ryssen's Avatar
I am going to have them as the upper tube in a Mu follower found couple of schemas amd an articel on that,so its an old tube,well I need an octal pentode with 6,3v heater.E180F is 9pin Maybe you could sell me a couple of those 6888?
Regards Åke
Old 11th July 2006, 06:59 PM   #5
VT67's Avatar
Why not, I don't have a direct use for them. I paid them 4,5€ a piece. If you want i can check about postage to Sweden?
Old 11th July 2006, 07:00 PM   #6
E180F and E280F are still around... They seem to be used in
Microphone preamps. In such cases, the Amperex SQ low noise
product seem to be preferred.
Why not use an EF86 as a substitute. This is a low noise pentode
also often used in phono and microphone applications. Sovtek
produces an excellent current product.
-- Jim
Old 11th July 2006, 07:09 PM   #7
Ryssen's Avatar
Yes but they are 9 pin noval´s i want octal.
Yes check the postage.Wat do you want for them each in $$$.you do have Paypal..
Regards Åke
Old 11th July 2006, 10:46 PM   #8
There's always the 6SJ7. RCA thought well enough of the 6SJ7 to make a "red" variant, the 5963.
Yet another possibility is the 6AC7.
Eli D.
Old 11th July 2006, 10:53 PM   #9
http://www.vacuumtubes.net/p5.pdf
These guys claim to have them @ 7.00 each. Brand?
"Make everything as simple as possible, but no simpler" Einstein
Old 11th July 2006, 10:53 PM   #10
Ryssen's Avatar
Thanks for the answers,I am about to buy 4pcs 6888.
Regards Åke
P3a mosfet equivalents djronbxs Solid State 8 15th November 2006 09:56 AM
I´ve made a Mu stage with 6888 and 6C45... Ryssen Tubes / Valves 13 27th August 2006 11:26 PM
6F1 and 6P2 Equivalents fmak Tubes / Valves 1 27th September 2005 05:17 AM
Help with Equivalents DieterD Parts 2 1st October 2003 10:58 AM
EQUIVALENTS palesha Solid State 5 28th November 2001 03:07 PM
Page generated in 0.10310 seconds (75.57% PHP - 24.43% MySQL) with 11 queries
