| diyAudio Sponsor | ||
Hello,
I'm looking for a little advice on filament supply: I need to feed two rectifier tubes with 5V/2,3A each and have a small toroidal trafo that's specified for 2* 9V/1,7A Can I use this trafo without overloading it (using resistors to reduce the voltage if still higher than 5V even with the bigger current draw)? (slightly) Overloading a block-core trafo isn't that dramatical experience tells me but I remember from electronics classes that toroidal trafo's saturate very suddenly = might be another cup of tea... Better to ask first than to be sorry later Cheers, Simon |
#2 | |
diyAudio Moderator Emeritus
#3 |
You could run the rectifier heaters in series... 4.5V each, maybe a bit more, since it's below the rated load.
Saturation is from overvoltage, not overcurrent. A small mount of DC will saturate a toroid - never use one with a half-wave rfectifier. |
#4 |
parallel the two secondaries to give 9V 3.4A. Adjust the output voltage by adding a few extra turns to each secondary to give nearer the 10V the two, series connected, filaments require. You need only 2.3A so you are well in and the transformer will run cool.
regards Andrew T. |
| Prevention of core saturation in push-pull topology | Tahmid | Power Supplies | 6 | 16th October 2008 04:16 PM |
| Core saturation and flux density calculations | machinehead | Power Supplies | 8 | 17th January 2006 07:45 PM |
| Air core vs Solid Core .. saturation | Madmike2 | Solid State | 2 | 6th July 2005 04:28 AM |
| DC Saturation current of Transformer core coil? | Mad_K | Pass Labs | 1 | 9th January 2004 06:11 PM |
| Page generated in 0.07191 seconds (73.81% PHP - 26.19% MySQL) with 10 queries |
