diyAudio Sponsor
Old 10th July 2006, 05:32 PM   #1
mickie is offline mickie  Germany
Default 6922 Heater - BIAS
Hi all,
i have implemented a voltage-divider in my WCF - Headphone - Amplifier (6922-Tubes) to bias the heaters at about 40V; connected to the center-tap of my Hammond 369EX (3,15 - 0 - 3,15V AC)
Could i (in addition to that) also put a small cap from the heater-pins to ground in order to reduce noise or would that interfere with the circuit/heater bias?
As a newbee, i'd appreciate any comments!
regards,
mickie
Old 10th July 2006, 10:00 PM   #2
EC8010 is offline EC8010  United Kingdom
EC8010's Avatar
Do it.
The loudspeaker: The only commercial Hi-Fi item where a disproportionate part of the budget isn't spent on the box. And the one where it would make a difference...
Old 11th July 2006, 10:03 AM   #3
thanks, i did it.
Believe it or not: sound improved.
mickie
Old 11th July 2006, 10:35 AM   #4
EC8010's Avatar
If you have an oscilloscope to put on the heater pins to compare before and after, you'll be able to see why...
heater current and 6922 - 6n6p swap Miniwatt Tubes / Valves 3 25th August 2008 03:07 PM
Caps in Voltage divider Heater Bias ? Renron Tubes / Valves 1 4th December 2007 05:14 PM
Variable 6922 heater to cathode voltage limit...? ashok Tubes / Valves 2 13th April 2007 08:16 AM
Heater supply recommendation for 6922? leadbelly Tubes / Valves 18 20th March 2007 02:14 AM
6CA4/EZ81 heater bias dsavitsk Tubes / Valves 5 13th January 2006 12:58 AM
Page generated in 0.08679 seconds (73.28% PHP - 26.72% MySQL) with 10 queries
