diyAudio Sponsor
Old 10th July 2006, 01:00 PM   #1
Mrpong is offline Mrpong  Thailand
Default 12AU7 testing result: Are these tubes still good?
Firstly, for four ECC82 Miniwatt tubes, I conducted the emission test with Funke W19 and got these values
Tube #1 - 11.0/11.0mA
Tube #2 - 15.0/15.0mA
Tube #3 - 12/12mA
Tube #4 - 11.5/11.5mA
I don't know what we can tell from these results. Are they still good? or is it enough to conclude?
Secondly, can we select two match pair tubes from these four tubes? My guess would be tube #1 and #4. Correct?
Thank you.
Old 10th July 2006, 02:14 PM   #2
Geek's Avatar
OK for life, I'd say. Few circuits actually run them that high.
Apply -9V to the grid, does the plate current nosedive on all of them fair equal? If so, they're good to go!
No. They have to be multi-point matched in their linear range.
Old 12th July 2006, 04:07 AM   #3
Thank you!!
Mini amp using 12AU7's as power tubes? porkchop61 Tubes / Valves 3 16th January 2008 12:23 PM
FS: Vacuum Tubes (12au7, 12ax7, 6dj8, EL84) mrdon Swap Meet 4 28th October 2006 08:13 PM
To Brian: XGC... any good result? dw1narso Chip Amps 3 20th January 2005 02:37 PM
-----testing Tubes---- ICARE Tubes / Valves 0 26th June 2003 01:38 PM
Testing Tubes Rino odorico Tubes / Valves 2 4th October 2002 06:31 PM
Page generated in 0.06514 seconds (66.86% PHP - 33.14% MySQL) with 10 queries
