| diyAudio Sponsor | ||
Hello, I'm buildin a little 1watt amplifier using a 6sn7 in push pull. I use a common cathode resistor. I am wondering what sounds better:
More plate voltage but less current, or more current with less plate voltage. Can I use no cathode resistor if I want maximum current (taking into account the maximum ratings of the tube) . Thank you! |
#2 |
In a push pull amp you want to bias it where there will be the least ammount of 3rd harmonic distortion but still allowing full swing. Since 2nd harmonic has a cancellation effect in push pull. The ideal biasing using same tube, and both in class A, will be slightly different as opposed to a single ended amp. Obviously if your going class AB then the biasing will be way different in push pull opposed to single ended. If the tubes are self biased you cannot remove the cathode resistor. If it's a fixed, self-biased mix. You can remove the cathode resistor as long as you re-adjust the grid voltage to accomadate the change.
| Plate Current VS Plate Voltage Graphs | Captn Dave | Tubes / Valves | 2 | 13th February 2009 08:57 PM |
| Best plate voltage for 6dj8 at +-6ma | npr | Tubes / Valves | 12 | 18th January 2009 02:47 PM |
| Darling amp plate voltage | mylesmf | Tubes / Valves | 14 | 12th January 2007 05:14 AM |
| Plate Voltage on 12ax7a | xasm | Tubes / Valves | 6 | 15th September 2006 05:02 PM |
| does plate current/voltage effect tube sound???? | benny | Tubes / Valves | 10 | 7th July 2004 01:18 PM |
| Page generated in 0.07586 seconds (72.08% PHP - 27.92% MySQL) with 10 queries |
