#2 |
Hallo Purer,
thanks that you share your schematic with us. As I see this is the Line Stage. Do you have the complete information on this Preamp? Phono? Power Supply? Reinhard |
#3 |
Please, I could use it too.
#4 |
isn't that the PS in the upper right hand corner?
#5 |
Oops forgot to ask my question... of those two transistors in the right hand corner, which is the BU805 and which is the MPSA42?
#6 |
Hello,
yes at the right corner is a part of the power supply. The complete power supply is more complex. There is no heater supply. As I know the original power supply works with cascaded Fets for each stage. Maybe purer gives us the whole information or can answer the questions. reinhard |
#7 |
#8 |
#9 |
hello Purer,
your first schematic looks like a photo from the original manual. It would be good if you scan the complete manual, incl. Phono and Power supply and send it to our e-Mail. Thank you in advance. reinhard Why don`you make your preamp a dc Preamp without the cap? |
#10 |
Account Disabled
I can't see your photo now please send me a schematic or some pcb files to ahtweb@hotmail.com
thanks a lot for your usefull suggestion regards AHT |
| Convergent Audio Technology (CAT) SL-1 preamplifier | hkaudiodiy | Tubes / Valves | 0 | 20th June 2008 02:41 AM |
| who knows LCY ribbon? LCY+Audio Technology? | iboxyl | Multi-Way | 1 | 15th March 2007 11:56 AM |
| Accuton vs Audio Technology | bssk | Multi-Way | 57 | 9th December 2006 07:04 PM |
| Convergent Audio Technology SL-1 Scematics | lilouxhk | Tubes / Valves | 0 | 19th November 2005 03:04 PM |
