change to grid choke? - diyAudio
Old 3rd December 2002, 07:32 PM   #1
Joel is offline Joel  United States
Joel's Avatar
Default change to grid choke?
Anyone have any experience changing the power tube's grid resistor to a choke?
Is there measurable improvement in performance?
Hammond has a 150H, 8mA model. It's only $19, so not much of a risk I suppose.
(tube is the 71A from my SE amp posted before)
Old 5th December 2002, 04:07 PM   #2
Joel's Avatar
I'll reply to my own post!
With a plate resistance in the previous stage of 10k ohms, using 2PiFL, the reactance of the choke at 20Hz will be 18,849.6 ohms... so, since 10,000 would be the half power/3dB down point, I will be under that amount at 20Hz. This is pretty good.
And of course at 20kHz, the reactance will be 18,849,600 ohms... no loss at the high end.
How's my math?
So, I think it should work out good.
Old 5th December 2002, 04:20 PM   #3
dhaen is offline dhaen  Europe
diyAudio Moderator Emeritus
dhaen's Avatar
Sorry Joel, no practical experience on that. They've banned the most prolific poster who could have given an answer - with his own personal charisma of course...
Theoretically.... there could be some xtra power in the bag, just as the grid is driven slightly positive. Also you might get away with a smaller coupling cap; but beware of resonance
Issues with grid choke phrarod Tubes / Valves 15 23rd August 2009 03:19 PM
Step down grid choke vs. interstage transformer jetbat Tubes / Valves 3 11th June 2009 03:35 AM
Grid choke as I/V? dsavitsk Tubes / Valves 1 8th April 2008 07:44 PM
Coupling caps size with grid choke? DHT112A Tubes / Valves 4 7th December 2006 06:22 PM
Could a filament transformer be used as a grid choke? Saurav Tubes / Valves 15 13th September 2003 01:18 PM
Copyright 1999-2017 diyAudio
