6A3/6B4G/6S4S(2A3/2S4S) project - Page 2 - diyAudio
Old 22nd September 2006, 09:28 PM   #11
Hello Andreas,
You really ought to look at the real world curves and op point given in the thread rather than just quote a text book on an unrelated case...
In other words the conditions under which the RDH statement is true are not the pertinent ones for the op points given in this thread.
The RDH conditions would apply if there was suffucent current at the op point for a lower load such as 3K to draw extra current at a voltage swing that was the maximum that a 5K load could swing before cutoff... however at the given op point the 5k load can draw the full current available from the valve before the valve hits cutoff... the whole point of a higher load at higher Va...
Note that I don't claim lower distortion from my op point and load at full power because it doesn't deliver that in this case - why? because I'm swinging a lot more volts than a 3k load can swing... so full power distortion is almost exactly the same...
You know valves are just like real life... practical experience building and testing things counts for a lot more than the ability to read a book - even a good text book like RDH4. Not that RDH4 is wrong but you need the practical experience to understand that the statements in the book are only entirely true under the conditions given in the book and are not universal truths...
As always rules and statements are for the guidance of the wise and the blind obedience of fools....
Andreas, Not that I think you are a fool but you need to look beyond the text in a text book to what is the really meant by the text.
James
Old 23rd September 2006, 07:42 AM   #12
Hello James,
the output power (in class A1) depends only from the plate voltage, the plate resistance and load resistance, not from the quiescent current (RDH4, p. 555).
The maximum output power condition is R load = 2 x R plate.
Increasing the quiescent current increases only the plate dissipation.
regards Andreas
Old 25th September 2006, 07:47 AM   #13
widowmaker's Avatar
Send a message via ICQ to widowmaker
Hello, James!
Please, attach your schematic, want to take a look...
High Tension Wires Department
Daniel Petrov also known as widowmaker
Old 1st October 2006, 08:40 PM   #14
Hello Daniel,
I've tried a few versions which often started out as 2A3 designs or 6B4G designs. Here are three, starting with a PP design.
It shows a 6B4G pair but I built it with 6S4S and used an 8K Ra-a output transformer. Va was 350 volts and Ia was 50mA.
I experimented with neutralising capacitors with this design but took then off the driver stage - they are still on the output stage.
Old 1st October 2006, 08:44 PM   #15
Here is an SE design. The first version that my son has used a 2A3 and a 2K transformer with a classic 2A3 op point. The second one I built used the 6S4S and a 5K output transformer with Va 350V and 50mA Ia.
Old 1st October 2006, 08:45 PM   #16
THe third one is in homage to a friend - Jonathan Noble whos designs inspired this approach. Its nice I intially op point but it is now running as per the above examples and sounding very very nice. Its more romantic than the pentode driven version but probably not quite as correct...
Old 1st October 2006, 08:50 PM   #17
Hello Andreas,
I wish you and your text books every happiness for the future...
best regards
James
Old 8th October 2006, 06:17 PM   #18
widowmaker's Avatar
In the third one fillament is AC...
What about 50Hz noise?
Old 9th October 2006, 11:01 AM   #19
widowmaker's Avatar
Need russian triode UB-110 (-110) for first stage of my new version of this amp...
Old 31st May 2009, 09:39 PM   #20
Send a message via MSN to feralmeida Send a message via Yahoo to feralmeida
Default PSE 6C4C
Hello Gentlemen
I have much interest in this project!!
My respect to the wise opinions
-JamesD practice in the land
-AndreasS on the theory
I am not engineer, nor as much cofoundation as you.
My materials are, 6C4C production SV 1964
(less, also of production year 88)
and OPT James 5K, with idea to connect, the load of 8ohm, to the secondary one of 16 ohm, in an attempt to deceive and to lower the vision of Paralell SE 6C4Cs configuration to a minor Ra
about this form, itself being in a Ra, higher, than of the Spec., and more in agreement with the subject than they are trying
(for another SE, if I have the suitable OPT, 2k5, 3k5 Ra)
Great surprise!!! in your attachments
even 1, with 6N3P-EB, in my thoughts, the pleasing SURPRISE with the possibility, to be able to use of my stock 6N3P-Dr (s) or 6N3P-E, (- EBs in the present distribution, fodder that is worse, by the year and different manufacture structure without mica additional superior, just as the Chinese),
and the last one with N2 tubes!?
I do not know, with a neon or light bulb of 75W???!
what would be the equivalent resistor in this circuit?
With its aid, and in my lack of knowledge, ......... more on the practice, that on
" very respectable " , theory!
Agreeing! , with tension and points of work, debated here! I am thankful for, any commentary and/or helps, that can give me, in my project PSE 6C4C, also, undecided, in using 6n6pi in configuration SRPP, .........
and like no? my favorite 6N1P-EB!!
and the possibility of 6H30P-Dr and - EBs,
Trying to use, solely, select tubes, of the Russian, military production,
in my stock 6S3P-DR triodes also.
Pleasing greetings,
and esuses by my Babelfish Inglish Translator
from Spain
Fernan
running 6S4S/6C4C hot .. calling widowmaker makeb4break Tubes / Valves 27 8th February 2009 10:25 PM
6C4C - 6S4S - 6B4G op points? danFrank Tubes / Valves 2 6th December 2006 07:51 AM
The 6b4g alexmoose Tubes / Valves 4 1st October 2006 11:02 PM
Another PP 6B4G Ciscokid Tubes / Valves 3 24th July 2006 11:26 AM
Help with 6B4G PP amp. AudioGeek Tubes / Valves 4 17th July 2005 03:53 AM
Copyright 1999-2017 diyAudio
