| diyAudio Sponsor | ||
Banned
Can I use triodes in place of Q13/14?
http://www.headwize.com/projects/sho...lmore4_prj.htm (hybrid electrostatic headphones amp) Since that's doing most of the voltage gain, seems to me a good place for triodes. |
#2 |
Banned
Come on, surely someone can help me?
#3 |
2SK214 has 50 Volts (approximate) between drain and source...
Audio Researcher Daniel Petrov also known as widowmaker |
#4 |
Banned
Well that could be raised (I could pull the cathode lower; I'm still winding the transformer so getting other voltages is not a problem). Or low voltage tube used.
#5 |
Banned
Anyone?
#6 |
Banned
#7 |
diyAudio Moderator Emeritus
That is one helluva schematic for a tube amp! One reason you're not getting replies could be sheer intimidation. Truthfully, I wouldn't know where to start commenting on your design.
In my experience, tube designers start off with tubes only, then maybe (but not usually) put in some SS devices where they can really do some good, e.g. for constant current sources/sinks, B+ delay circuits or rectifiers. Tube designs tend to be very simple. That's my 2 cents. |
#8 | |
Banned
Umm, not my design. There's a reason I posted a link in my first post. It's an electrostatic headphone amplifier. And the only part that really matters here is the third stage...
And I had a very specific question: Quote:
#9 |
High gain, good linearity, and low plate voltage don't often happen at the same time
![]() ECC86/6GM8 may work better here than 6DJ8 - it is specifically a low-voltage design - but don't write off the 6DJ8. With a CCS load they can do quite well at low plate voltages, much better than you would guess looking at the curves in the datasheet. I have a circuit running on the bench now at ~30V plate voltage (48V B+), 2mA CCS plate load for two parallel sections, giving 0.08% THD at ~3V RMS out, ~10V RMS max out at 5% THD. The same circuit gives more output swing with ECC86, but an Amperex 6DJ8 has lower distortion. A modern JJ 6DJ8 is not as good at this low plate voltage but still works OK. Beware fairly large variation in characteristics tube-to-tube at this unusually low operating point. Adjustable bias and/or paralleling multiple sections is a good idea. (I'm working on a simple hybrid amp design). Pete |
#10 |
Banned
Er, that tube only uses a 30 V supply. I'm running the 6DJ8 at 130 V in the simulation and not getting enough gain. When I said low voltage, I meant on the order of a hundred volts.
| TubeCad's Hybrid amp question | Tyimo | Tubes / Valves | 9 | 1st September 2006 08:17 AM |
| hybrid rectifier question | dr.strangelove3 | Tubes / Valves | 17 | 4th October 2005 01:28 AM |
| Question about a hybrid PSU design | reaction | Tubes / Valves | 2 | 10th October 2004 11:45 PM |
| Page generated in 0.10994 seconds (78.39% PHP - 21.61% MySQL) with 10 queries |
