diyAudio Sponsor
Old 30th June 2006, 11:03 AM   #1
Unhappy Help on a LUXMAN MQ 3600
Hello all,
I've a Luxman Mq3600 to modify for the 6550 tubes.
Anyone have the original and modified scheme to send me?
Thanks for your help.
Maurizio
Old 1st July 2006, 06:48 PM   #2
Hi There:
here is the link for the schematic:
http://f2.grp.yahoofs.com/v1/ILimRB_..._MQ3600_p1.gif
art
Old 1st July 2006, 09:52 PM   #3
Alain Dupont's Avatar
Maurizio,
Here it is:
http://telefunken.te.funpic.de/luxman/MQ3600-02.jpg
Regards.
Alain.
Old 2nd July 2006, 10:23 AM   #4
Hi art,
I can't open the link you send me..This is the modified version?
Can you help me about?
thanks
Old 2nd July 2006, 12:25 PM   #5
Maurizio,
what I did find on:
http://www.allaudios.org/detail-7211106.html
AFAIK, an 8045G IS a 6550 wired as a triode (by jumpers in the base).
See: http://www.triodeel.com/images/8045.gif
Most of the "8045G" labelled tubes I've seen were US made 6550's
with jumpers added in the base.
| This may be a difficult and expensive
| change, though less expensive than finding new 8045Gs.
Wiring the socket for a 6550 or KT88 is not difficult,
nor should it be expensive.
Ned Carlson Triode Electronics Chicago,IL USA
www.triodeelectronics.com
Then connect about 100 ohm, a couple watt resistors from pins
| 3 to 4.
| With no output tubes installed, fire it up (preferably with a
| Variac, but *SAFETY FIRST* in any case - allow no children or
| pets in the room).
| Observe voltages at points marked "C1" and C2". Adjust the 30K
| ohm bias pots for maximum voltage.
| Power off. Observe all supply voltages and wait until they've
| fallen to a low level, maybe a coupla volts.
| Install your new matched quad of Svetlana or maybe JJ power tubes.
| Fire it up again and observe. Everything OK?
| Bias is measured at the cathode pins (pin 8). I'd run modern
| tubes at between 50 and 70 mA (500 mV and 700mV on pin 8).
| The 10K ohm pots are to balance the current in each pair.
| Try various bias currents and use the least that doesn't affect
| sound quality. And no more than 80mA.
Hope this will help.
Alain.
Old 2nd July 2006, 11:43 PM   #6
Hi Maurizio:
here is the schematic, copied from yahoo luxman group:
art
Old 3rd July 2006, 06:39 AM   #7
Thanks a lot ART.
Tell me, the OY 3.6k of MQ3600 have ultralinear taps?
Cause in the original scheme with 8045 doesn't appear.
Thanks.
Maurizio
Old 3rd July 2006, 02:55 PM   #8
hi maurizio:
I don't know. Never owned one, should not make any difference for switching to 6550. the schematic I copied from luxman yahoo group.
may be you should consider joing the group.
art
Old 3rd July 2006, 03:18 PM   #9
al2002 is offline al2002  India
al2002's Avatar
Originally posted by Alain Dupont
Maurizio,
snip
snip
Alain.
The NEC 8045 was actually a TV sweep valve, internally triode connected.
6LF6 or similar valves should work well, don't know what the going price is now.
TA-3600 amp. - info needed! edl Solid State 4 28th April 2006 10:09 AM
TA-3600 amp Diode Solid State 11 28th April 2006 12:47 AM
Page generated in 0.10442 seconds (75.14% PHP - 24.86% MySQL) with 11 queries
