diyAudio Sponsor
Old 30th June 2006, 10:54 AM   #1
Mrpong is offline Mrpong  Thailand
Default Changing from 6X4 to EZ81
I have a tube regulated power supply PCB using 6X4, 12AU7, and EL84. The problem is: 7-PIN tube sockets and 6X4 are quite rare in Thailand, so I'm going to modify the PCB a bit by changing 6X4 to EZ81 which requires a 9-PIN socket.
What I'm not sure is: are there technical or electrical contraints for 6X4--> EZ81? Can someone give me both 6X4 and EZ81 datasheets?
Sorry for my poor english & thank you in advance for every comment.
Old 30th June 2006, 11:23 AM   #2
I don't see any problem in changing the 6X4 for a EZ81. Just take care that your heater supply can feed the extra 0,4 amp consumed through the EZ81 filament. Maybe you can try EZ80, this one has the same filament supply than the 6X4 (or are you limited to new production EZ81's?)
You can find the datasheets at www.duncanamps.com
Old 30th June 2006, 11:31 AM   #3
OK. Thanks..
My transformer is "0-6.3V X2(1.5A), 320V-0-320V (100mA), 0-15V X2 (2A)". Is "320" too much for 6X4 and EZ81?
Old 30th June 2006, 11:34 AM   #4
ez80 is rated for 350-0-350 input, the 6X4 for 325-0-325
EZ81 rectifier noise Stixx Tubes / Valves 24 22nd December 2007 07:25 PM
FS: 6 pieces EL84 and 2 x EZ81 jean-paul Swap Meet 0 15th October 2006 06:41 AM
Hammond Transformers and EZ80/EZ81 oodi Tubes / Valves 24 2nd February 2006 02:42 PM
6CA4/EZ81 heater bias dsavitsk Tubes / Valves 5 13th January 2006 12:58 AM
EZ81 tube rectifier kephaudio Tubes / Valves 13 29th March 2005 12:44 AM
Page generated in 0.06819 seconds (70.18% PHP - 29.82% MySQL) with 10 queries
