diyAudio Sponsor
Old 29th June 2006, 04:08 PM   #1
Default What do you think about my design (based on IMPAMP)
Hello!, this is my first thread on this forum. I'm from Spain so I apollogize for my english. Also I'm a totally newbie in hi-fi.
I wanted to build a little project to introduce myself in hi-fi and I saw the IMPAMP www.impamp.com which has been discussed previously in this forum.
http://www.diyaudio.com/forums/showthread.php?s=&threadid=72699&highlight=impamp
This is my design:
I thought that the 12AU7 could be a good choice but I've seen similar designs with 6SN7 o 12BH7. I simulated it in LTSpice and the 12AU7 gives me the best THD specs (I don't know how much accurate these spice models are).
Saludos!
Old 29th June 2006, 04:35 PM   #2
SY's Avatar
Warning: the linked pic carries spyware and scumware!
In any case, don't trust simulations when it comes to distortion. 6SN7 will give much less distortion than 12AU7.
edit: do you really need that much gain?
“Listening to records is like ****ing a picture of Brigitte Bardot.” - Sergiu Celibidache
Old 29th June 2006, 04:58 PM   #3
Sorry for the pic I thoght that imageshack was clean, where can I place the picture for more safety?
About the gain on the op amps it is adjusted to give the maximum output with a portable mp3 player, I have other adjusts for +4db input.
Old 29th June 2006, 05:52 PM   #4
SY's Avatar
You can upload a jpeg here directly. Use the "Attach File" option.
Old 29th June 2006, 06:04 PM   #5
Netlist is offline Netlist  Belgium
Netlist's Avatar
I believe you are correct. It's their advertising banners and links they don't care much about.
/Hugo
Old 29th June 2006, 10:50 PM   #6
So what do you think about the circuit?
DIY something like iMPAMP?? nkko Tubes / Valves 41 9th October 2011 10:41 PM
PCB design for MOSFET based HP amp? zebra100 Solid State 0 1st July 2009 09:01 AM
LM4780 Based Amp - Design Help Needed surajram Chip Amps 6 24th June 2008 01:25 PM
My TDA1543 DAC based on P. Daniel Design Algar_emi Digital Source 8 11th March 2006 02:12 AM
Page generated in 0.08893 seconds (71.93% PHP - 28.07% MySQL) with 11 queries
